Question about HP Pavilion ze2000 Notebook
Ze2000 Hi, I took my laptop apart and see the capacitors in reference but how can i tell if they are bad or not? I have a volt meter to test resistance but i feel im getting a false read. Any help you can provide is greatly appreciated. Thanks, Frank
  • 186 Answers
I donot think that it is that eazy to find out the faulty Capacitors in Computers.
I recommend you to check if any of the Capacitor is bulged like say, out of its regular shape.
If you find any, I beleive that it is faulty.
Hope this helps...
Posted on Oct 06, 2008
Air compressor 2hp 230v 1ph motor. I need to know how to test a starting capacitor. Thanks
IF you don't have a special meter, that costs more than the capacitor, just replace it. The meter is called an ESR meter and they are $$
Aug 26, 2017 | Air Tools & Compressors
How to if fan is bad or capacitor is bad
You can test the capacitor with an analog volt meter, one with a hand not digital. Make sure that the capacitor is discharged, it is kind of like a battery in that it will store electricity. You can short the terminals with a serce driver but make sure to wear protection like rubber gloves and use a plastic handled screwdriver that is clean of oil and grease and dry. Set the volt meter to Ohms on a mid level setting and touch the meter leads to the terminals of the capacitor. The meter should spike up and then drop off. Reverse the leads on the capacitor and touch it again and ou chould get the same. Placing the leads on in the same direction twice should not cause a reaction on the meter at all. If the meter does not react as described, the capacitor is probably bad.
Jun 14, 2012 | Heating & Cooling
How do i test a capacitor?
easy with a volt meter,but depend on what kind of capacitor you talking about there its lot and lots capacitor design...used Volt Meter to tested red for +Positive (power)and Black for -Negative (grown) for volt with respect or power flow,never never used (AMP) on volt meter to test ...
Apr 02, 2010 | Coleman Mach 15 Air Conditioner
No power. I changed fuse but microwave blows it immediately.
Be very careful! Standard microwaves have 2100volt capacitors and commercial ones 4000 volt capacitors.
*Decharge your capacitor(s) before doing diagnostics*.
You are now testing the high voltage side (as it works on convection). The main components are a transformer, a capacitor, a diode and a magnetron (havent seen a triac in a panasonic residential). If you have a proper meter that can test uf, decharge the capacitor, then test the capacitor, if it reads 0, you need a new capacitor (10$ used typically, 14$ new from ebay). To test the magnetron, decharge the capacitor first, remove the spade connections, test each leg to the frame of the microwave... if it shows measurable resistance, the magnetron is bad. The transformer is not something you test as I personally dont have a 4000 volt meter. If the diode, the magnetron and capacitor are okay, then the transformer is bad. To eliminate any other function, disconnect the low voltage to the transformer run a micropower cycle and check the fuse.
Hope that helps. My first instinct is the capacitor.
Nov 14, 2009 | Panasonic NN-T888S Convection/Microwave...
Gateway MX6930 Notebook will not power up
Yes a bad battery could cause this, or a bad battery control circuit. If it works with the battery out then it's one of these two issues. If it's the control circuit, there's not much you can do, I'm afraid, but the only way to be sure is to get a new battery (or borrow one for the same model).
Jan 18, 2009 | Gateway 7330GZ Notebook
Surface mounded capacitor ze hp
No, don't mess with the surface mounts.
You don't even know their value!
Oct 09, 2008 | HP Pavilion ze2000 Notebook
ZE2000 No power issue
Check on the motherboard if there is a fuse. It may look like a diode or resistor.
Does it work on battery, if you have a charged one?
Jul 14, 2008 | HP Pavilion ze2000 Notebook
No power on HP Pavilion ze2000
Remove the power cord and the battery. Hold down the power button for up to one minute to discharge the laptop.
Re-install the battery and power cord and see if it turns on.
Apr 19, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion ze2000 Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
