Question about Epson RX595 Photo All-In-One Printer
Printed photos are yellow tinted and faces washed out
Just replaced LT Cyan cartridge. Never had this problem before. I have cleaned nozzles and printed test page. Doesn't look good and has some kind of codes below it: JU2477 and QP100653. Don't have a clue here.
SOURCE: Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Posted on Oct 28, 2007
J PENGUIN
  • 12 Answers
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Posted on Dec 31, 2007
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
SOURCE: The new light cyan cartridge
Replace the other cartridges with either remanufactured or new Epson cartrdiges.
Posted on Jan 25, 2009
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
New ink installed in printer but prints yellow
Printer output only green means yellow and cyan ink only. Try to doa nozzle check, then head cleaning. After the nozzle check again.Are all colors (c, m, y, k) appear? Possible causes are that the inkdries on the nozzle head.
Jan 02, 2012 | Office Equipment & Supplies
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
Mar 27, 2011 | HP DeskJet F380 All-In-One Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IP4300 only recognizes magenta OR cyan
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I am having color problems with cyan and magenta with my i9900 printer. I need to understand how Cyan, Photo Cyan, Magenta and Photo Magenta affect the other colors? I know Cyan and Yellow make Green and...
hi!!
try to perform maintenance of your printer
try to open it removed the cartridge
use a screw driver and then clean up the nozzle
use alcohol and cotton buds dry it well then
placed it back again!!!
Nov 10, 2008 | Cannon Office Equipment & Supplies
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Epson RX595 Photo All-In-One Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
