We have an AEG Plasma monitor DPD-4200 DDPTCC02799 S/N. This plasma monitor contains a teletext facility. We have not been given a service manual and our screen changes from bright colours to dull colours and back again. It also goes sometimes to a grey screen and the screen flickers up and down. We took it to the TV serviceman who cannot fix it without a service manual. He thinks it requires Power supply PCB and Logic PCB. Where can I find the service manual and the parts in New Zealand? Also, apparently some picture and/or text (such as mute symbol and a few texts from menu) have burned into the plasma. How can this be prevented from happening as we thought AEG is a quality brand name and we have the monitor only 4 years.
techman
  • 3130 Answers
SOURCE: colours all messed up and reds dull look brown
You should first turn off all the color on the set, or play a b&w Tape or dvd. What were looking for here is, what the color balance or grey scale looks like first. If a B&w video or whatever looks true to grey and black and white then you have whats called croma problem in the color or video demodulator. My friend I wish there was an easy way to assist you in this type of repair but theres not, as it could be a problem in the video/croma demod section of the video jungle IC and this is not a user serviceable part or repair as thers several issues concerning Hi voltage as well as x ray radiation. Now if its a problem where the grey scale or the B&W is not true to color then theres a problem in the R G B driver circuits. Could be a simple drive adjustment or even a soft or weak picture tube. I hope if your not a tech you seek a pro to assist you in this troubleshooting as this could be dangerous for you as there are no user serviceable parts inside this set. Good Luck
Posted on Jun 21, 2006
premtech
  • 934 Answers
SOURCE: Red noise or flicker on bottom half a plasma screen
The old saying that a pictures is worth a thousand words could have been looking at this one... If the lower screen had been streaked in B&W or bands ran completely through the picture Old Drummer I would suspect the logic board also but that's lower y-board failure.
Bill
Posted on Nov 15, 2007
  • 298 Answers
SOURCE: No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Posted on Nov 22, 2007
  • 26 Answers
SOURCE: Plasma TV buzzing
If the adjustments on the power board are correct and if you are not at high altitude, the plasma display panel is defective. If the set is off warranty, it is not cost effective to replace the display panel. If it is off warranty, you should give the manufacturers Customer Relations a call. The phone number is usually right on the back of the tv. The manufacturer of the tv might make a warranty concession if they are concerned about their brand reputation. Some manufacturers find it less expensive to just switch brand names rather than make good on defective products. If all else fails, you might get some money back by selling the circuit boards on eBay.
Posted on Feb 20, 2008
SOURCE: Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Posted on Mar 06, 2008
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
I have a Pioneer DPD 505 PG Plazma. It tuns on, I have sound, but the picture takes sometimes up to 45 minutes to appear and become clear.
Contact the authorized service centre for Pioneer. If Va or Vs voltage to display panel differ from the stated value, this should happen. These voltages will be marked at the silk screen at the bacl of each Plasma display, and it should be very accurate, in case of all plasma displays. These two voltages will differ to screen to screen; and will be marked as stated above to all plasma display panels. Adjustment to this voltage have been provided at the main power supply regulator board to these TVs too.
Actually, adjusting these voltages is a skilled work. So; It will be best to contact either any service technician or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 15, 2014 | Pioneer Televison & Video
How to bring teletext up on remote control for 2011 plasma Vivo flat screen tv ?
www.avsforum.com/forum/.../1429512-service-menu-code-vivo-tvs.htm..
Aug 26, 2014 | Televison & Video
How to use the teletext
HI,
There is no teletext option avilable in this model (LG 50PG20) .
Ajin
Jun 09, 2012 | LG 50PG20 50 in. Plasma HDTV
Hi there, i have a hitachi display plasma monitor and i have a missing part that controls the t.v. apparently its a box of some sort but i dont know exactly it is that i need to get it going. please help...
hi there.the box you need is known as a media box,and basically contains the tuner,teletext decoder etc.have a look on ebay,there may well be one listed.also the link cable is very expensive new...most of the older plasmas used a separate media box.as it is,you should only be able to use the set as a computer monitor.
regards,
steve
Sep 13, 2010 | Televison & Video
I have a LG 50PX1D-UC plasma TV with a black vertical line
You could have a Driver Board that has a loose connection or a Ribbon Cable that has a intermittent connection to the Plasma Panel, or a defective Plasma Panel. Either one could cause the problem and I would recommend only a Qualified Service Person to check it out.
Here is LG's Customer Service Number. 1800-243-0000. They could direct you to a Local Service Facility.
I hope this helps,
Sky Assoc
Oct 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
I have a 42 inch plasma and teletext wont work any
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
Jul 22, 2009 | Televison & Video
Teletext is not in English
HOPE THIS WILL BE OF SOME HELP,TUNE IN YOUR TV AGAIN FROM SET UP......
Dec 04, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
