Question about GE Refrigerators
Dripping water from a ge fridge with a ice and water dispenser. why is the water spout dripping?
    Problem Solver:
  • 13 Answers
Hello ghreay..
do u've Water on floor outside of refrigerator? plz do the follwing..
do u've Water inside the refrigerator? plz do the follwing..
  • Clean the drain tube
  • If you have an ice-maker, check refrigerator and ice-maker for level.
thank you for using fixya..
Posted on Sep 28, 2008
My wife noticed our side-by-side GE Turbo Cool water dispenser was dripping water so a quick look in freezer showed a huge ice buildup in the drip tray that had frozen back into the spout. We emptied both...
let see if I understood correct me if i'm wrong! When you close the freezer door water star running from the dispenser? If so you water valve solenoid is staying in the open position just replace it.
Dec 21, 2014 | Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a side by side fridge/ freezer bought new 5 yrs age and the water/ice dispenser keeps leaking water. I noticed the the lever in the dispenser area seems loose. what would cause this type of problem?
One of two thing. Either the flap is not closing all the way allowing condensation to build up and drip, or you have a seaping water valve allowing water to seep out of the water spout insde the door.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Whirlpool Refrigerators
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Drips water out of Ice maker spout
There is a valve that controls the flow of water at your door. Take the front console off and take it out. There will be wires attached to the console for your water/ice control so make sure you either tag or write down where these wires go. Then replace the valve you will clearly see that opens the water up. Take down your model and serial number down and go to your local appliance dealer so they can cross reference the part number OK? Randy B. A.I.R. Appliances
Feb 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ice/water dispenser drips after using
afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water Dispenser Not Working
the water spout on the dispensor unscrews this is a clog issue take it off and then run water becarful this does have a spray effect all over but it allows water to flow
also there is the problem of the water tube up the door has kinked when closed this is a big deal with front fridge water the ice dispensors tube goes up the back
May 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
