Question about XION PowerReal 600 (XON600F14T201) 600-Watt Power Supply
Power Hiccups and Cycles
I have a Xion 600W modular PSU and a Xion 1000W modular PSU. My problem is that they both love to turn on and off about 15 times before the computer can even POST... That means I have to wait an additional 2 minutes before I can use the computer. Any ideas?
  • 144 Answers
Faulty electrolytics in the power supply. Buy a new one or get it serviced.
Posted on Nov 09, 2008
My 1000w eliminator inverter only puts out 100w. overloads and goes to Fault
Check your battery voltage when running the inverter. At 100W, the voltage may drop several millivolts maximum, initially and will slowly drop. At 100W, the inverter may draw 15 to 20 amps from the battery. At 1000W, the inverter will draw upwards of 100A which is very hard for most batteries to provide for very long. I have a 5000W inverter connected to a 12V, 830AH battery bank. At 600W output, the inverter draws 70A. At 1500W, it draws almost 150A. At 600W output the battery voltage will drop almost 2 volts over 8 hours of operation. At 1500W, I would get maybe 5 hours, but I have never run a load like this for any length of time.
If you put a 100W load on the battery and the voltage drops 2 volts very quickly, then the battery is shot.
Jan 11, 2018 | Inverter Electronics - Others
Cooler Master 1000w Silent Pro M not compatible with MSI MS-7548 (Aspen) motherboard?
http://www.coolermaster-usa.com/product.php?product_id=2949
So you're using the same CPU 4+4 Pin x2 power cable on both rigs?
(One of them)
Yes, I see it's a modular cable design, and the CPU 4+4 Pin x2 power cable, can be used as a single 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
ALL Yellow wires are 12 Volt (DC) wires.
ALL Black wires are Ground wires.
ALL 12 Volt wires go to ONE single 12 Volt power rail, in the Power Supply, BUT; there is nothing saying an individual Yellow wire may be bad.
This is why I wondered if you are using the SAME power cable CONNECTOR. Same power cable.
Yes?
Then suggest it has something to do with the Active PFC circuit.
http://www.hardwaresecrets.com/article/Anatomy-of-Switching-Power-Supplies/327/6
Not aware of any setting to change in BIOS Setup utility - Power.
BUT, I do not know everything! lol!
IMHO there is no reason it will not work, unless as said; something to do with the Active PFC circuit.
From here let's hope someone who really knows what is going on, will post.
Regards,
joecoolvette
Dec 10, 2012 | Computers & Internet
You guys was helpful last time so I thought I would ask more!!!! DJ equipment Gem Sound amp EVA-3955 at 8ohms 2x250w blew 2 Tr-150 15'' 8ohms rated at 600w blew. what replacement should I go with same size...
Typically large speakers like that blow up because you are trying to put frequencies into them that they can not reproduce. How are these units connected? Is the crossover frequency correct for these 15" speakers? Putting signals higher than about 1000Hz will start to heat them up. too much heat = blow-up.
Also, I'm not familiar with the tr-150s. Is the 600W rating a PEAK rating or continuous?
Dan
Jan 06, 2010 | Audio Players & Recorders
My psu went out i have a soyo sy p41845pe mb what the highest watt psu i can get for it
you can have any power supply you want on it aslong as its the right size for the case say for example you went out and bought a 1000W power supply you system would use around 200-400W depending whats installed it just means the other 600W dosnt get used
Sep 25, 2009 | Soyo SY-P4I 845PE Motherboard
I have a power supply that is turning itself off immediately after switching it on it is a new motherboard as well Any ideas why ?
I think either the MB or the CPU is with problems.
Try (2 after 1 works, 3 after 2 works...):
1) only PSU+MB+CPU and Fan - works? beeps like crazy?
2) add memory - works? single beep?
3) add/connect video - any image?
All other connectors off (disks, etc) only PSU, fan and case buttons.
If you don't get past 1), go back to the store and have it tested/returned there.
Mar 20, 2009 | OEM Systems Xion / 400-Watt / ATX / 80mm...
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
XION Case and Supply
Try unplugging, then plugging back in the 20/24pin power connector. When you plug in the power connector, make sure the power supply is OFF and the switch in the back is OFF and nothing is plugged into the computer.
Jul 21, 2008 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
Compatible amp for subs
hi there. yes it should work providing you have the correct wiring it for it, if you buy the LV 416 enquire about a wiring kit to fit, most will. theyre normally around 20pounds. most amps will be compatible with most subs. i run both my 12inch 1000w off one 1200amp at half power, they kick lovely and i have no problems.
any other quiries please ask
adam
Nov 10, 2007 | Legacy 2CH 1000W AMP Car Audio Amplifier
Can't turn on PC, Presario SR2163WM
You sound like you know what you're doing, so I expect you've made all the motherboard connections(Same as the original PS). Does the switch work when you test it? If so, it sounds like the PS is DOA. I've had bad luck with cheap power supplies.
Sep 17, 2007 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
XION PowerReal 600 (XON600F14T201) 600-Watt Power Supply Logo
135 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
Farokh Merek
Farokh Merek
JonSnell Electronic
JonSnell Electronic
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
