Question about Hoover Vacuums
My 5 green brushes dont go around on my steam vac from hoover
  • 37 Answers
Can you spin your brushes by hand? if not you have a bad turbine. if you can clean the lint trap under the small clear window in the front of your steamer.
Posted on Sep 28, 2008
Hoover steam vac the brushes dont spin
It could be one or more different things. The brush assembly might have an obstruction. The shaft coming out of the brush assembly might have broken. It could be a clogged screen or filter. It could be the turbine is not working properly.
Feb 23, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover Steam Vac Replacement Drive Brush instructions
Here's a link to the diagnosing:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
And if you find out that you need to replace the turbine, here's a link that shows you step by step how to replace the turbine:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Sep 01, 2012 | JTRhomeswarehousecom Hoover Steam Vac...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
My hoover spin brush steam vac brushes wont spin
Unplug vac turn it over and check for belts that drive the brushes
They are located at the very end of the brush They are probably missing
or they snapped and sitting in the housing somewhere. If you ar mechanically inclined not very difficult to replace. While you are at it clean all the hair and fibers that usually accumulate around the brush bushings
That is usually the culprit that wears down the belts
have fun
Feb 06, 2012 | Hoover Vacuums
The Hoover steam vac dual v does not spin its brushes and I dont know how to dismantel it to view the belt .
There is no belt on the steam vac - it operates on air flow. Remove the brush and insert a flat screwdriver into the square hole. If it does not turn, the turbine has seized up and must be replaced. Remember that the brush will not turn unless the lower tank is in place, and the handle is tilted back.
Jan 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
78 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
