1995 Ford Ranger Supercab Logo
A
Anonymous Posted on Nov 16, 2011
I replaced the ignition switch in my 1995 ford ranger now the alarm won't stop
John
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Feb 13, 2015
John
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
9874
Points
57
Disconnect both battery terminals, wait a minute the renect starting with positive. Check you fuse as well or a crossed wire while you moved them
ZeroNullity
Level 2:
Scholar:
New Friend:
  • Expert 71 Answers
  • Posted on Nov 16, 2011
ZeroNullity
Expert
Level 2:
Scholar:
New Friend:
Answers
71
Questions
0
Helped
20448
Points
217
95 Ford Ranger Auto Alarm Wiring Diagram.
You need to re-check your ignition wiring. Here is the wiring for the alarm.
Battery Constant 12v+ Positive Wire (+): Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Red/Light Blue
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Light Green/Purple
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Light Green
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): White/Black Or Brown
Parking Light Positive Wire Location: At Headlight Switch Or Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Pink/Yellow (Type B)
Power Door Lock Negative Wire Location: In Either Kick Panel
Power Door Unlock Negative Wire (-): Pink/Light Green (Type B)
Power Door Unlock Negative Wire Location: In Either Kick Panel
Door Trigger Positive Wire (+): Black/Light Blue
Door Trigger Positive Wire Location: In Drivers Kick Panel
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Yellow/Light Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Any Wire With A Tan Stripe Or A Yellow Stripe
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Light Green
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Dark Green/Purple
Factory Alarm Disarm Wire Location: Low In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
1995 Ford Ranger 2.3 L coolant temperature gauge not working like it should
possible low coolant level
loose wire on sender unit
faulty sender unit
take the wire of the sender unit and put it to ground
with the ignition switch on , the gauge should go straight to hot
that indicates the circuit and gauge is operational which leaves the coolant level and sender unit
I have a 98 Chevy Malibu Ls and the ignition won't
Inspect the old ignition cycle which is out.Is there any problem noticed of Ignition cylinder getting worn out.
Because when issue of ignition not turning off,its faulty ignition lock cylinder or faulty ignition switch.I suggest re-inspect the new ignition cylinder.
For more help,click the help link mentioned below:----
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These will help.
Thanks.
1995 ford ranger wont come out of park
try disconnecting the rods from the ignition switch shift lever inhibitor.this is basically the mechanism which prevents you from turning the ignition switch to the 'lock' position when the shift lever is not in the 'park' position
3helpful
2answers
My 1995 ford ranger pick up speedometer, radio, break lights, wipers and turn signals dont work
On the ford ranger wiper motor not working, this is how u fix it. I am a licenced autobody mechanic for mercedes and my son bought a ford ranger and of course the wipers were not working-neither did the dome light and door chime.I told my son too replace all fuses ,switch and motor. And still nothing.Remove radio there is a pcm in behind- ours was unpluged. When we plugged it in the door bell would not shut off and the dome light stayed on. In stead of unplugging the pcm remove the light if wd40 does not work on the door latches. And to stop the door bell ringing remove the plastic cover around the ignition and their is a single wire with a blue connector just remove the wire it is the wire closest to the key and tape up the end and problem solved guarenteed . my email is [email protected] I will walk u through it .
91 Ford Ranger XLT, 4 cyl, manual 5 spd. Engine
most likely right on top of steering colum around have way down
2answers
I have a 1995 ford ranger and the door alarm keeps beeping ..how do stop it?
It has a bad door ajar switch. Try spraying wd-40 in the latches. The switches are in the latches. Try this for a couple of days. If it still does it, replace the switch. But since you don't know which one, you might have to do both. Try the drivers door first.
5helpful
2answers
Ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
