Agitator is not engaging properly,it will engage when I put pressure on it forwards or backwards.
I have had the same problem is your machine really really old? Do you have a model # or picture?
Posted on Sep 28, 2008
I have a toro zero turn z4200 starts and runs fine but when I put arms in gear, it will not move forward or backward.
Make sure the drives are engaged. Under the seat and towards the rear are two thin metal levers with finger loops. These are used to disengage the drives in order to push the mower when the engine is off. Levers towards the back to engage.
Good luck
Mar 30, 2015 | Toro Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
My caterpillar D7F was shifting forward and backward one day we came to start the machine it wouldn't engage in reverse after sometime it stop engage forward. what could possibly be the problem?
This could be a very simple fix to an oh my god. First check your fluid levels. My initial thought is how it slowly started to stop shifting is that you need to fill your transmission fluid. If that is the case after it is full then you will be able to shift fine. Second part of your problem then is finding out where it is leaking and get that fixed. If it is just a leak count your blessings, fix it before using it again and always check your fluid levels often.
Nov 12, 2012 | Mitsubishi WD-62528 62" LCD HDTV
I have a celebrity scooter that powers up great and every thing seems to operate properly except it will not go forward or backward. It makes no sound when engaging thumb switch.
Make sure the drive lever/freewheel brake is engaged. Usually it is on the lower back bottom of the scooter or check your owner's manual.
Oct 29, 2010 | Pride Mobility Products Pride Celebrity XL...
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Maytag washer m/n PAV3240AWW
I suggest changing the belt for a new one, in fact if this model has 2 belts, replace them both.
I ran 2 laundromats... this occured frequently due to over loading the machine and then the belt would get damaged just enough to foul up the proper agitation and the spin/drain cycle.
Just change the belts and i'll bet that will get you back into service!
Let me know.
K
May 26, 2009 | Maytag Washing Machines
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
