Question about HP OfficeJet 7310 All-In-One InkJet Printer
My HP OJ 7310 all-in-one did not pick up papers.
The printer display repeatedly told me to put papers into the tray and hit OK, which actually had plenty of papers, about 30 sheets. I took out the papers and put them back neatly time after time and hit OK accordingly, but the printer simply would not pick up papers. Please advise a solution.
  • 3 more comments
  • kyeung6024 Sep 27, 2008
    Yes, the printer clicking continuously and something sounded moving aimlessly.
  • kyeung6024 Sep 28, 2008
    I used a flash light to look into the printer from the paper tray side. As soon as I hit OK, I saw the two ink cartridges went to the left side and then cycled in short distance about two three times with light bumping sound. All the rubber rollers are rotating, but the upper long rollers, which I thought was suppose to come down to carry the upper sheet of the papers forward to the feeding rollers at the back, stayed put. I think this is the problem. Is this a mechanical problem or an electronical sensing problem? Please advise.
    I could grap the large wheels and rotate them, but I needed to use a certain amount of force and they did not rotate freely.
    I am quite handy. I service my own car and repair mechanical watches during my younger years. Maybe with your detailed instruction or a few pages of repair manual emailed to me, I could service the feed roller Please advise.
  • JDTec
    JDTec May 11, 2010
    Do you hear the paper feed rollers turning? Does it make any noise?
  • HP Master
  • 4,338 Answers
The first ting I would do is clean the paper feed rollers with a cotton pad and alcohol. The rollers may have a build up of paper dust that are makind the rollers slip.
Posted on Sep 27, 2008
  • JDTec
    JDTec Sep 28, 2008
    The feed motor may be bad. try rotating the with your fingers . see if they move freely
  • JDTec
    JDTec Sep 28, 2008
    If that is the case, the feed roller is bad. needs service.
How to fix error 41.3 on a HP P4515 printer. Have checked all paper settings and tray settings.Changed paper pick up rollers also.
Hi
This error means that the media in tray XX doesn't meet the specified standard of the tray. The specified tray is loaded with media that is longer or shorter in the feed direction than the size configured for the tray. Please check the paper size in current tray or touch OK to change the tray.
To resolve this issue Touch OK to display tray size. Reconfigure the size in the tray so that it uses size of media required for the print job. If the message doesn't clear automatically from the control-panel display, turn the MFP off, and then turn the MFP on.
Restart the printer and repeat the above procedure if issue is not resolved.
Daniel Scott
Jun 14, 2010 | HP Office Equipment & Supplies
It says its out of paper, but there is paper....
take paper out turn printer off.
put paper back in and turn printer on
Are you sure the paper is loaded into the lower tray?
make sure it is pushed all the way back in the paper tray
Nov 13, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My hp printer is telling me that i need to add
Not sure what printer you have but most consumer models don't actually detect paper in the tray. These machines will give an out of paper error if the paper is not picked up from the tray.
If the machine sounds like it is trying to pick up the paper but giving the error check and clean the pick up roller and look for something blocking the paper path.
hope this helps
Mar 15, 2009 | HP Office Equipment & Supplies
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Hi my printer doesn't pull paper from tray1 even if it set to pull paper automatically from tray 1 and 2 inadditon to this it needs manuallly feed papers.
My HP OfficeJet 7310 behaved correctly on the automatice paper feed for a long time and then began to be unable to pick up the page or would grab 2 or 3 pages at once. I was about to spend the $$$ to replace it, maybe $400 at that time. Instead I watched it work again and angin or not work. Noice the 1 inch square piece of cork? I went to Hobby Lobby and for less than $2 bought a roll of very thin cork. I cut an inch square and replaced the one on the machine and it has worked perfectly since. I still have 99% of the cork roll. What it?
Jan 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
