Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
My maytag Jet Clean EQ Plus seems to be stuck on the three minute delay
The red light for the three minute delay is staying on and I can't get a cycle to start
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi 9897,
I'm Harvey the Master Plumber.
Your problem is: The red light for the three minute delay is staying on and you can't get a cycle to start
First try to reset the d/w. Turn off the power at the circuit breakers for ten minutes. This useually solves the problem. If not, you're likely looking at a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
My maytag dishwasher dosnt work. the delay light 2,4,6 lights just blinks. I would like to know the reset code to see if i can do a cycle run.
I pressed heavy wash 3 times and then start to make it perform a field test. It tested fine, but it stuck at 61 minutes for an hour while I was testing auto clean. Another thread indicated that the controller cable interface was getting moist.
Dec 05, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag jetclean dishwasher eq plus
What is the model number?
May 21, 2013 | Dishwashers
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Mar 03, 2010 | Dishwashers
Maytag eq plus, not cleaning properly, seems the
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
I have a mdbd880aww model and it seems that the
The pump and impeller needs cleaning or replacing.
Remove the spray arm and base to access the impeller and pump inlet for cleaning and inspection..
Mar 26, 2009 | Dishwashers
Panel lights all flashing when trying to start a load
Try pressing delay/resume then drain/off. In some cases you might need to do delay/resume then drain/off twice.
Dec 03, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
532 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
