Have a dynaglo portable propane heater, it will light, but after a few minutes it sputters and stops working. it will relight but does the same again. dan
  • 32 Answers
You will have to take out the fuel line to get to the filter or clean out the port at the carbuerator. It sounds like the fuel flow is not ample enough to continue burning
Posted on Sep 28, 2008
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
My patio heater will light and run for about three to five minutes then shuts off, I can wait a few minutes and relight and it will do the same thing.
Hi, This can be caused by using butane during cold nights. Butane will start to freeze on cold nights but propane will work up to -6 . If already using propane then the most likely problem will be a worn thermocouple, these are consumable items. Found this site very useful, patio heaters problem solving.
Sep 19, 2011 | Napoleon Lifestyle Collection Bullet Model...
Atwood 6 gal w/h won't stay lit longer than 12 minutes
After it is stored for the 2 weeks, do you turn water on to it, then bleed out any air through the taps before lighting it? If not try that and see what happens and let me know if any different.
Mar 14, 2010 | RTO Atwood Water Heater - 6 Gal LP
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
Burner on Charmglow patio heater will not stay on.
believe it or not, the propane tank may be too full. The vapor space is taken up and you have very little vapor. Run some warm water over the tank. The garden hose may be enough but if you get no frost line the water will need to be warmer. The warm water causes the liquid fuel to turn into vapor. Do not use boiling hot water. Another thing is oening the valve. Most propane tanks have safety valves. If the gas escapes faster than a normal rate, the valve closes. Open the valve slowlyand lt it burn for about 10 minutes before opening the valve further. It will get better as the fuel is used up and the vapor space in the tank increases. In real cold climates a heater blanket, sleeve is used tho keep the bottle warm. The vapor also creates the the needed pressure to move the gas through the system to the burners. Good Luck-Ned_
Sep 15, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Wall heater not working properly--sputtering blue flame
Ok, either your fuel pressure is too low or too high.. When you light the unit, Light it in low, then turn it up slowly Just crack open your tank valve.about1/4 turn. The air in the tubes has to be displaced with gas before you get a good flame
Dec 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
