Powermac I have an old powermac 6800 series that I want to dispose of.  I want to clean off the hard drive.  It hasn't been used in many years.  The light on the monitor comes on when plugged in but the tower doesn't do anything.  I can't get a screen either.  What should I do?
  • aelester Sep 28, 2008
    how do I take the hard drive out of the powermac series6800? I want to get recycle the rest of the computer.
  • 4,338 Answers
I would take the hard drive out and destroy it if you do not need the data on it.Since it does not work, I would recycle the rest of the unit.
Posted on Sep 27, 2008
Brother MFC 6800 won't send scan results to iMac. The scan function appears to work, although nothing appears when using iPhoto or Picass for Mac. I am using Mac OX 10.6.5
I had the same problem. I knew the scan function was not broken because I could use it with my old PowerMacG4. But no go with the new Intel iMac, and no amount of driver updating or other OS fiddling solved anything.
I luckily found another MFC-6800 to test. And to my surprise scanning is working, and printing is much improved (no more "offline printer" when it's clearly online). The difference between the two: firmware version. My MFC is dated from 2001, while the other one is from 2004. For the date see the label behind the machine.
Now, why does scanning work on my old PowerMac G4? Apple probably changed something in the Intel drivers or the USB circuitry, or Brother didn't adhere to proper standards in 2001. Or it may be as stupid as an inability of the older Brother board/firmware to deal with USB 2 levels, even throttled down to USB 1.1. Who knows? Anyway I'm in contact with Brother and hope to get a way to upgrade the firmware in my printer.
Did you try scanning with Graphic Converter? Some Adobe products need updates to properly scan in Snow Leopard.
Hope this help.
Dec 13, 2010 | Brother MFC 6800 All-In-One Laser Printer
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Nov 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Will fifa 11 work on ati hd 4750??
Minimum System Requirements for Fifa 11: Operating System : Microsoft Windows XP / Windows Vista / Windows 7
Processor : Intel Core 2 Duo at 1.8 GHz / Athlon 64 X2 Dual Core 5400+
Video Card : 256 MB VRAM - (NVIDIA GeForce 6800 or better / ATI Radeon X1600 or better) **
Memory : 1 GB RAM (2 GB required for Windows Vista / Windows 7)
Hard Disk : 6.5 GB of free Hard Drive space
Sound Card: DirectX 9.0c Compatible
Direct X : 9.0c
Controls : Keyboard & Mouse
Installation : DVD-ROM Drive
**Supported Chipsets :
NVIDIA GeForce® 6xxx series (6800 or greater)
NVIDIA GeForce® 7xxx series
NVIDIA GeForce® 8xxx series
NVIDIA GeForce® 9xxx series
NVIDIA GeForce® GTX 2xx series
ATI Radeon™ X1600 (X1600 or greater)
ATI Radeon™ X1800
ATI Radeon™ X1900
ATI Radeon™ X1950
ATI Radeon™ HD 2xxx series
ATI Radeon™ HD 3xxx series
ATI Radeon™ HD 4xxx series
Yes, it will work on an ATI HD4750.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Nov 02, 2010 | EA Sports Video Game Consoles & Games
It didn't drain > only 2 1/2 years old > and I clean my dishes good before loading etc... ?? Help
run CLR through it
check that the drain hose is clear, did you recently get a new disposal?
check routing of drain hose to disposal, do you have an air gap at the sink before the disposal? is it clear?
hard water deposits?
Sep 04, 2009 | Dishwashers
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
first check and make sure that the water is not leaking from the hose connection to the dishwasher or the drain fitting itself. If neither of these is the problem and it is definetly leaking from the housing then replace. I recommend the Badger series disposal with a 5 or 7 tear warranty I have installed them for years and never had a single problem.
Jul 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Powermac g4 will not turn
this is a common problem with G4 Quicksilver. Your power-supply is defect and has to be replaced. I have 4 G4s in my lab with the same symptom: a short flash of the power-button light, sometimes it turns on, but mostly the machine is dead.
May 07, 2008 | Apple Power Supply 344 Watt PowerMac G4...
Gateway Hard drive replacement
Any PATA hardrive. Parallel also known as IDE. I would go for SEAGATE barracuda, simple, effective, and a 5 year warranty.
So, you will be looking for a 3.5 parallel hard drive. Check if your computer has a partition limit, ie, pre firewire 800 machintosh G4 towers cannot take single drives larger than 120 GB.
ATX is your motherboard form factor.
Keep me posted.
Oct 25, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
