Question about EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA
I had a new G31T-M mainboard! I use it with intel quad chip! I followed the instruction in user`s guide but it can not start! it stops at screen with a note "press F11 to start BBS POPUP". Can u tell me how to go over it! It stops with CPU and System Fan Run ! I use 2x2 Kingston 800
  • 3 more comments
  • Anonymous Nov 08, 2008
    I have the same problem.
  • galaxycafe Dec 12, 2008
    Yep I got this problem too. Just hangs at this screen. Says to press DEL or F11 but when I use the keyboard nothing happens. I thought the keyboard dead so tried it on another computer. It's OK. I have Quad Q9550 CPU, Intel G31T, 4 GB Corsair RAM. All fans are running. I got Zalman 9500A LED. Help! Suggestions. Thanks everyone.
    Cheers James
  • jw3712 Dec 27, 2008
    No response with del or esc on keyboard to enter setup. Have a new G31T-M mainboard! I use it with intel E8500 I followed the instruction in user`s guide but it can not start! it stops at screen with a note "press F11 to start BBS POPUP" and 4G DDR2. The keyboard LEDs flashe twice then nothing. HDD, CD/DVD and FDD are not connected.
  • Vik
    Vik Dec 30, 2008
    I have similiar problem. I have EliteGroup ECS G31T-M Motherboard with 4G DDR2 800. It posts description inluding F11 and reads RAM setup. Thats all.  Never gets to screen to post " DEL to set BIOS". Keybord is not active. I tried 3 working keybords, changed SATA WD 500G HD  , changed IDE WS HD which seems to power,  I connected audio out, DCD drive seems to power. Stuck it is in the same sequence.
    Vik
  • vinban Jan 04, 2009
    Fry's upgraded the BIOS and it worked. However, when i use the DEL key to get into the BIOS, the number is v 02.59 which is not same as 08/07/17 on ECS website. Also, the front panel leds and speaker does not work. Anyone has a suggestion - how to determine the BIOS version and get the front panel to work?
    Thanks
Re: 'old' ECS G31T-M
Hi coolee101.
I made it work with BIOS 080717s reflash downloaded from ECS web.  It is 'pain' to do that, but it's over... I followed intruction from 'Guest' on October 29 2008; I installed Intel Celeron and checked the AMI BIOS setup is working. After that I download reflash info and updated BIOS from WEB page.  Here is more detail on steps:
Step 1 - make BOOT disk. I used XP OS Step 2 - Download BIOS, extract and keep DOS utility program  Step 2B - add connection on MB to enable REFLASH. ( Install connection of pin 5 (write protect) to pin 7 (GND) on connector SPI ROM.). Step 3 and Step 4 are per ECS pdf instruction - ( I used 'DOS'  exe + BIOS file name) Step 5. Disconnect  WRITE PROTECT 5-7 on MB Step 6 Install your original CPU (I 've got Intel Duo E85000 w/ mb, 4G 800). ... restart to see it work... it's time to be cool again!
Good luck Vik
Posted on Jan 10, 2009
Go into control panel, open up the icon realtec hd sound effect. left click on audio I/O, left click on little blue wrenchtowards the top of screen. Put check mark in the box next to Disable front panel jack detection. exit out & plug into front asound it it will work, the back sound will still work to.
Posted on Jan 02, 2009
  • glg22351 Jan 02, 2009
    go into control panel, open up the icon realtec hd sound effect. left click on audio I/O, left click on little blue wrenchtowards the top of screen. Put check mark in the box next to Disable front panel jack detection. exit out & plug into front asound it it will work, the back sound will still work to. This fix was for the ones who could not get the front audio to work. Sorry if I posted it in the wrong problem.
Had a new G31T-M mainboard! I use it with intel quad chip! I followed the instruction in user`s guide but it can not start! it stops at screen with a note "press F11 to start BBS POPUP". Can u tell me how to go over it! It stops with CPU and System Fan Run ! I use 2x2 Kingston yes my story is the same
Posted on Nov 30, 2008
You don't say what processor, but most quads need a bios flash. you'll need a floppy and a processor that works in that board. I used a celeron 430.
Posted on Oct 29, 2008
Label manual of ecs g31t-m
Dear,
You can download your user manual from the link below.
Enjoy...
http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/G31T-M_V2a.pdf
best of luck!
Mar 18, 2012 | EliteGroup ECS G31T-M Motherboard - Quad...
Driver pour g31t-m9
Hello download here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=958
Good luck
Dec 23, 2011 | EliteGroup ECS G31T-M Motherboard - Quad...
I need drivers for ecs g31t-m rev 1.0 for win xp
hell guys, please i need VGA driver for ECS G31T - M os win xp..
Oct 20, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
Driver for ecs g31t-m series with 6 ports audio
you collect in intel g31 mother board driver from www.intel support.com
Nov 22, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Need to know the location of the bios chip on a esc g31t-m v1.0 motherboard is it next to the battery? Failed bios flash want to remove bios chip to send in to badflash to have it reflashed.
Not all BIOS chips are removable. Your board uses a AMI Bios and u can quickly identify it by searching for the AMI symbol or lettering. If the Bios has a seat you can remove it: ttp://www.biosman.com/images/extaction_plcc_points.gif
If it is soldered on...sorry...u need a new MB.
But have you tried clearing the bios and then reflashing it?
Jun 06, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
No sound when i installed new OS
i'll be grateful if u mention the type of OS. anyway the error message is for wrong driver. rollback or uninstall the installed driver and try another if u have other drivers inside ur mainboard CD or auto update the driver from internet or other media that contains the appropriate driver. when the driver found a suit it will install automatically.
May 04, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
G31t-m7 motherboards can use inter Pd. 800 cpu
if your post code has completed so
heat problem or smps problem or ram problem or
remove all datacable exm : hdd ,writer,fdd and power on
Jan 16, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Motherboard boot up problem
Try clearing the cmos bios on the board there is a jumper on it
Jan 02, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
EliteGroup G31T-M initial boot stops
Remove the CMOS battery for a few hours then place it back in. I bet it sound like the CMOS is stuck in a loop.
Dec 30, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
EliteGroup ECS G31T-M Motherboard - Quad Core Support, Intel G31, Audio, Video, PCI Express, 10/100 Ethernet LA Logo
1,734 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
