Question about Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32" Wont let me change channels or go to menu
My tv wont let me Go to menu,Source, Vol or channels using the tv buttons or remote. The buttons on the tv work i know they do because the little blue lights blinks when i hit them,the same thing with the remote, But noithing happends. It is stuck on one channel which is channle 57 here and is bravo.
  • 2 more comments
  • hydrotone Mar 12, 2009
    I have the sme problem (Wont let me change channels or go to menu). I can't find the part anywhere (782-L32K51-560E). I wish I could find one for about $80.
  • hydrotone Mar 15, 2009
    Same problem. Does anyone know if any of the mainboards are interchangable, such as 782-L32K51-560E, 782-L32K51-560F, 782-L32K51-560D or 782-L32K51-560C?
  • hydrotone May 11, 2010
    Is this part available anywhere for any price (782-L32K51-560E)(mainboard for is-lcdtv32)?
  • Anonymous Mar 28, 2014
    dstv remote stuck on channel 144 but cant change to another channel how do I change the remote so that I can change channels
  • 27 Answers
There is a problwm wit hyour mainboard you can buy one on ebay for about $80 and to remove just take off back panel and unplug about 5 wires and remove 2-3 screws on the left side / the same side that your power ch+/- ect is on. and swap out.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
How do I do a channel scan?
Press Menu on the TV (second button from the left) or the remote. Use the Vol + / Vol - buttons to highlight Tuner, only available when the input is the TV (press TV/AV to get to the correct source) mode. Press Ch+/Ch- to highlight AutoProgram and then Vol+ to start the search for channels. The TV will show Tuning Finished when done and then go to the lowest channel found. If you want to add or remove stations, tune to the desired channel, then press Menu, and highlight Tuner, Ch+/Ch- to highlight Add/Erase, then Vol+/Vol- to set Add or Erase. Press TV/AV/Exit to get out of the menu.
I hope this helps.
Jul 28, 2010 | Philips Magnavox 27MS343S 27" TV
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
We need a large display Simple to use remote for insignia lcdtv 26in. Of course the code for the tv is needed.
Go out and buy her one of those super cheap Universal Remotes. They cost less than $10 and work great (if you get a decent one) for just about any TV & LCD TV. And the cheap ones generally don't have all those crazy menu option buttons all over them. There's one I saw at Lowes that looks a lot like a flip-up cell phone. The basic buttons are on the outside and the "extra" buttons are on the inside. I learned just recently that to program an Insignia LCDTV to a Universal Remote you use the Mitsubishi Code.
Jan 19, 2008 | Insignia LCDTV26 26 in. Television
Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
Aug 01, 2006 | Sansui COM3101 13" TV/VCR
Insignia IS-LCDTV32 32 in. Television Logo
843 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
