Printing with vista
My laptop runs vista, and I have a wireless network. I can't get my printer to work wireless, only wired. WhenI have is connected through a use cable, it works.
  • sptwld494 Sep 28, 2008
    It doesn't matter if I use a new printer or an old one. Where is the wireless driver located? os it for the perinter(disk installed), or within vista? Thanks for your help, as it is much needed. Also, I downloaded the fix program from microsoft and still no luck.
I have so many problem in my car dont go stright alwase ging round.
Posted on Sep 28, 2008
    President:
  • 1,263 Answers
Your wireless protocol may not work with vista because the driver is probably not compatable with the programing.. i would like to know if you have had the printer when you used wireless with windows xp or is it a new printer and you have not installed the wireless driver for it
  • Ronald Mueller
    Ronald Mueller Sep 28, 2008
    the wireless driver should be on the install disk for the printer.you should be able to download the driver program for it from the printer's web site.
How to set up wireless printing with disc
Here are the minimum details needed to answer this kind of question:
1. Operating System :
Windows XP, Windows 7, Windows 8, Windows Vista?
2. Printer make/model:
(this is important to determine the wireless properties of printer)
3. Network Connection:
(is the laptop connected to the same network as the printer)
If you are working with a new printer (see item 2) and you have a network on which you have your notebook connected, there are so many possible ways to connect the printer to the network that it's hard to say.
If you are working with an established printer that has wireless services running, you may need to know either the Network Name of the printer or the IP Address of the printer.
Your best bet is to make use of hp's extensive Wireless Printing Center (see link below).
Wireless printing center
Feb 26, 2014 | HP Pavilion dv6000z Notebook
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Printer is connected via USB to a Win XP PC and prints fine. However will only print test print from networked Vista laptop?
I take it you the Win XP PC is on the same network that your Vista Laptop is on and that some how you must be able to share the printer through your XP PC?
I think you are experiencing the many issue that Vista has to offer.
Maybe think of actually seeing about placing the printer on a Network print server. This would solve your issue. I did this with my Brother Laser printer and it works great. I believe the print servers are coming down in price I am using a TRENDnet TP100 and it works great with my two wired network desktop PCs and the two wireless notbooks that both have Vista on them.
Blessings,
A/V Media Guy
Nov 22, 2009 | HP LaserJet CP1215 Color Printer
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can't connect Xp laptop to 64Bit Vista PC to be able to print across wireless network
yes easy to fix, just share your print driver give it a share name like canonmp780 on the pc it is connected to
then get on your laptop asuming its on your wireless network and in the start bar run this command. \\ your computer name one printer is connected to \ canonmp780.
so if your computer name is windows and your printer name is canonmp780 the run command will be: \\windows\canonmp780 hope this helps and really easiest way to connect to it.
Canon tech
Apr 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Samsung Printing Trouble
make sure that when you go to print under propertys choose color tab and then color
Apr 07, 2008 | Samsung CLP 300 Laser Printer
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Wireless printer
it sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Jun 12, 2007 | Linksys (WKPC54GCU) 802.11g/b Wireless...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
