Question about Refrigerators
DCE33 Ice Machine
Did you every figure out the problem with your Scotsman ice machine. I have the same machine and I think the same problem. It works well, but it never seems able to fill up and thus it runs all the time. My understanding is that it is supposed to only need to run a few hours a day once it fills up.
I believe it was the inlet water valve that needed to be replaced, but I got so fed up with the noise and repairs on this machine that I purchased a Whirlpool ice maker. So far, it's been great. It is much more quiet and produces 50 lbs of ice in 12 hours and shuts off until some of it melts. It only produces more ice about four times a day as it melts.
Posted on Sep 27, 2008
Scotsman ice machine DCE33
if it's plugged in and you didn't trip a breaker, the switch in the timer has been known to go
Jan 21, 2014 | Kitchen Appliances - Others
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Jun 19, 2009 | Scotsman DCE33PA1SC 15in Built-in...
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Aug 05, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
492 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
