Question about RCA HD52W59 HDTV Projection Television
Rca 52inch hdtv
Model # r52wh77 serial# g462c100x chasis itc22a
I HAVE A RCA 52 INCH R52WH77 TV AND THE COLOR IS LIKE RAINBOS AND ALL DISSORTED. THE SOUND IS FINE THE PICTURE IS ALL BRIGHT COLORS AND TWO TONE AND SHOWING DOUBLE IMAGES WHAT CAN I DO TO FIX IT
Posted on Mar 22, 2011
    Genius:
  • 1,030 Answers
I would first look at the fl231 problem article under tips and tricks. this tv has no stks ics this could be a simple repair.. i repair alot of these at the shop. let me know/ the first question.... do you have the convegence option in the setup menu. if you do this is a good thing
Posted on Sep 29, 2008
  • 10,594 Answers
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Posted on Sep 28, 2008
My 52inch floor model turns on then immediately turns off? rca hdtv
Thats usually caused by failed or cracked solder on the flybacks connections to the deflection board. I would check the solder first if that doesnt solve the issue you may need to replace the deflection board.
Jul 24, 2011 | RCA HD56W66 56" HDTV
RCA Model R52WH77 ..picture goes out after about 20 minutes, sound stays on.
Replace the deflection board. You can get a new ITC222A deflection board PSB-260 from www.tvrepairworld.com which also comes with instalation instructions.
Aug 01, 2010 | RCA R52WM24 52" HDTV Projection Television
I have a RCA HDTV model R52WH77 and the picture is like watching a 3D movie without the 3D glasses.
The ITC222 and ITC222A convergence option missing repair kit should repair that issue. The kits available at www.tvrepairworld.com and contains the parts and the CD with instructions
Oct 14, 2009 | Televison & Video
RCA 52 INC MODEL R52WH77
From the symptoms you describe. you have the fl231 fuse problem. Congrations this is a simple fix. please read my article "the fl231 fuse problem" in the tips and tricks section
Apr 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca tv will not power on. no sound no picture
you need to call jerome at tth electronics in canton,ohio
330-371-9896 he will solve it for you.
Mar 28, 2009 | RCA Televison & Video
No Convergence
yes that model is the same itc222 chasis... the fl231 problem is common on all itc222's even more so on that model .. consult the tips and tricks section for the fl231 problem repair instructions
Jan 11, 2009 | RCA R52WH73 Projection Television
RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
Oct 07, 2008 | RCA HD52W59 HDTV Projection Television
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
52inch RCA model#D52W20 tv
the d52w20 rca chasis itc222 can be difficult to troubleshoot sometimes. there a few things you can assume at this stage. ONe it is NOT the fuse. The processor in this set is seeing a voltage or saftey shutdown issue. and is shuting the set down for saftey. THis is where the troubleshooting begins. High voltage or overcurrent conditions are generely the problem. \technicians have speceil computer diagnostic equipment that can read error codes in the processor. much like in a car. but without it yo0u pretty much have to check things like horizontal ouput transitor.
Mar 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
322 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
