Question about GE WSXH208A Front Load Washer
GE front load washer model WSXH208A1WW
This machine was bought used but everything seems to be intact and all pieces there, but when it does in to the spin cycle it jumps, bangs and shakes across the floor, can you help us with what may be wrong with it?
  • 32 Answers
Look in back of mach for 4 shipping bolts.they are usually housed in a rubber grommet surrounded by a yellow plastic shaft.if they are there remove all 4 of them.also remove bottom access panel by taking out 2 screws(1 on each bottom corner)look for 1 or 2 yellow steel bars connecting base to tub.if they are there remove.if none of these shipping bolts or brackets are there,you have a broken basket.if that's the case,try to get your money back or buy a new mach.it is a $600 repair..good luck
Posted on Sep 28, 2008
Ge washing machine will not drain
Drain by lowering main drain hose below pump into shallow bucket, remove front lower panel , take large hose off back of pump clean out hose, may have to take 2 screws out of pump mount to look in pump mine was being stopped by a nail,the$6.75 in change was still in the hose
Jan 23, 2013 | GE Wsxh208a1ww Front Load Washer Washing...
Is the GE WSXH208A1WW a stackable washer with the GE DSXH43EAOWW Dryer?
Could you please describe the problem you are having a little better?
Nov 27, 2012 | GE WSXH208A Front Load Washer
How to dissasemble GE model wsxh208a1ww
log on to applianceaid.com/appliance-repair-help. find your make ,model and they will give you step by step instructions on the repair. the site also includes pictures of every detail. good luck ,Steve
Oct 15, 2012 | GE WSXH208A Front Load Washer
Wsxh208a1ww very loose tub front to back
Check to see if there are broken shocks attached to the tub. Here is a link to the parts if you find that they have failed.
Oct 14, 2012 | GE WSXH208A Front Load Washer
Only 7 yrs old and repairman says it needs a motor control will cost 380.00? GE WSXH208A1WW Its only me home and I don't wash more than 2-3 loads a week. Is this common?
That is about the right price. Here is a link to the part and you could replace the part yourself. Just remove the 2 screws that hold the front bottom kick plate on and remove it. The control board will be on the bottom right side toward the back of the machine.
Regards, Richard
Aug 22, 2011 | GE WSXH208A Front Load Washer
Ge washing machine wsxh208a1ww, The dial seems to get stuck during all cycles. If you go out and manually turn the dial one click it will keeping going. But it takes forever to do a load of laundry since...
The bad news is that you most likely need a new timer. I get mine (used) from e-bay after looking up the parts at "Sears Parts" by model number. Sears will sell you new parts by model number for your GE.
Be blessed.
Nov 08, 2010 | GE Washer Washing Machine Timer WH12X1000
Changing the belt on a GE front loading washer
Hello , i can try to help , I have always got these belts on by starting the belt on the small pulley/motor , then rolling it on the large pulley , kinda like putting a bike chain on. Let me know if you have any other questions and how it turns out.
Phil
Jan 07, 2009 | GE WSXH208A Front Load Washer
Serial Number
go to dealer and get the numbers off a different one....same model
Jan 03, 2009 | GE WSXH208A Front Load Washer
Grease on clothes?
This is a 50 year old problem on washers.  All brands.  You just got lucky on this one.
If you buy a new one, consider a unit built by Whirlpool.  They also make Kenmore and others.
Nov 12, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
1,019 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
