Question about Kenmore 98702 Stacked Washer/Dryer
Dryer not dryin well
I have a kenmore stackable washer/dryer model # 41794712400. I can put a freshly washed load of cloths in and turn it on 100 on the high heat setting and when the buzzer goes off the cloths are still mildly damp. I have notticed that the element is still working and its getting the required voltage needed to work properly. coluld this be thermastat problem? If noot what could it be and how difficul would it be to repair? Thanks for the help!!
Check the lint catcher. Efven though you may have taken out lint it could still be clogged. Take it out and run under water. If water starts to collect then you have an invisble layer that comes from fabric softner. You just need to clean it out with warm water and soap. The only other thing it could be is lint has collected on the vent leading outside from your hose. Just simply remove it and you should be ok. I've had simliar problems with both scenerios.
Posted on Oct 06, 2008
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Sears Model 417 stackable washer and dryer
The model that you provide is incomplete. However, if the washer loads from the top, they cannot be separated. If it loads from the front, they can.
Apr 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
123 people viewed this question
Sal De
fordexpert
Robert Rankin
