Question about Kenmore 22062 Top Load Washer
Kenmore 22062 gunk on clothes after washing
I've had this washer for 6-7 years and it works great, but lately when I pull clothes out after washing some of the laundry has a slimey gunk on it. Sometimes it's just spots of wet lint that come right off, but other times it's like sludge that is stuck in the folds. I'm wondering if there's a filter or something I need to clean?
Thanks!!
  • 1314 Answers
SOURCE: kenmore washer always makes lint on clothes
yeah check my four boxes and send me an e mail at b4829@yahoo.com ref lint on clothes
Posted on May 22, 2008
  • 113 Answers
SOURCE: Spots on my clothes after washing.
the transmission seal may be going out leaking oil
Posted on Apr 24, 2009
  • 212 Answers
SOURCE: Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
Posted on Jun 24, 2009
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
  • 1937 Answers
SOURCE: Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0705087.pdf
Posted on Apr 13, 2010
Testimonial: "The answer was sent back quickly. The information was very helpful."
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Washer leaving black gunk on clothes
The agitator and s/s bowl needs to be removed for cleaning.
You need to use a pressure washer to remove buildup on s/steel bowl
The bucket aka tub needs to be cleaned also check for items that may block or jam pump at the bottom of the bucket.
reassemble your machine, it should do a better cleaner wash.
Feb 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE2PLUS washer has a water leakage problem when washing and water just leaks from inside during the cycle. We tried to look for it and could not figure out from where it is dripping heavily. Any...
Thank God for the internet and Google! I came across this, and another thread about the same problems. I "cut and pasted" the solution below:
(another user posted this solution:) "We also had water pour out the dispenser of our 2 year old HE2 washer. Derek's answer helped us realize that a trapped garment was the probable cause. We were actually able to pull the sock out of the intake tube without taking everything apart!
We opened the clothes door and felt around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). We felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. Once enough of the sock was exposed we used pliers to grasp it more firmly and pull it completely out.
The sock was a write-off (much longer and full of holes) but the washer is working great!!"
Word for word, we had the same exact problem. The machine started spilling water from the dispenser area and making an odd noise. We even pulled out a sock (now much longer and filled with holes!) What a relief to find these threads.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite 22062 wont spin makes buzzing noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 04, 2008 | Kenmore 22062 Top Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Kenmore 22062 Top Load Washer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
