Sub-Zero 685/S Stainless Steel Side by Side Refrigerator
Problem for Sub-Zero 685/S Stainless Steel Side by Side Refrigerator
We have a 5 year old side by side sub zero fridge/freezer (largest size)
By sheri6286 on Sep 27, 2008
the side of our sub zero (where the freezer is) is really hot where the door connects. The fridge side is ok...everything is cold, but service light is on. What should I do???
Comments:
Sep 28, 2008
- I hear a fan, but the refridgerator is built in and my husband is not here to help me pull it out. I looked inside the freezer and see no frost build-up anywhere. Should I turn the fridge off?
Solution #1
posted on Sep 27, 2008
Not Rated)
techgurus
Rank: Wiz
Rating: 77%, 107 votes
check whether the temprature is set properly in the freezer on proper level.
Comments:
Sep 27, 2008
- OFF the unit to get it defrost. defrost the unit for 24hours and then set the tempratures to the normal , not very high not very low.just adjust it to the normal level.and it will reset it self after defrosting.ON the unit.let it work for 2-3 hours and then adjust the temprature as you set regularly and then check mostly it works after resetting.
Sep 28, 2008
- yes turn the fridge off.do not touch any of the internal components in ON condition also remove the power wire from the electric outlet for more safety.
Solution #2
Not Rated)
navidh
Rank: Wiz
Rating: 84%, 49 votes
Check the fan in the rear of the unit.  If it is running, check the rear panel inside the freezer section and tell me if there is frost building up on the outside of this panel.
Popular Solutions for Sub-Zero 685/S Stainless Steel
Questions and Unsolved Problems for Sub-Zero 685/S Stainless Steel
Do you recommend Sub-Zero 685/S Stainless Steel Side by Side Refrigerator?
Answer
Answer
Where can I get a door gasket for the built in 685 sub zero it on the refrigerator side
Answer
refrigerator not getting cold but freezer seems ok. temp says 37 but seems really warm
Answer
door panel to dispense ice and water doesn't work. the bulk ice dispenser inside the refrigerator is... (More)
Answer
My control panel, in the blue lighted section, is flashing 'SERVICE'. Help!
Answer
Vacuumed coils, however, refrig continues to run. Adjusted temp, temp in within 'safe' zone, but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
