Question about Kitchen Ranges
I have a ge profile performance range the broiler works but the oven will only heat to 100 degrees. the self cleaning will not go pass 100 degrees also
  • Anonymous Mar 13, 2014
    tappen oven wont heat pass 100
  • 943 Answers
Hi thanks for the question i would check the lower element the bake element that should solve the problem thanks the appliance doc
Posted on Sep 27, 2008
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
Oven does not heat over 100 degrees
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile oven won't heat up
Check the temperature sensor with a OHM meter.
It should read 1100 ohms. If not, replace it.
Otherwise make sure the glow bar ignitior is coming on.
Ignitors however can glow and still be bad.
Feb 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler quit
Have you checked the broil element resistance? Unplug the range and remove the back cover. Remove the wires from the broiler element and place a meter across the element posts. See if the element reads close to a short (It should read very low resistance if good). If the element reads infinite (open), you will have to replace the broil element. If the readings are normal, you may have a bad Electronic Range Control (ERC) board. The board controls the bake and broil features of the oven through two separate circuits. Usually a relay on the board goes bad. Since the ERC is considered "non-serviceable", replacement components can be hard to find. For this reason, the entire assembly is usually replaced. The ERC runs around $100 for your range, while the broil element can run anywhere from $35 to $60. Now...as far as your self-cleaning function is concerned - most electric ranges use BOTH elements to super heat the oven cavity to about 700 - 800 degrees F. With one of the elements not working, there's a good possibility the self-cleaning function will not work either Double check the items I mentioned and let me know if this helps you.
Feb 02, 2008 | GE Spectra JBP78 Electric Kitchen Range
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
