Question about Samsung CLX 3160fn All-In-One Printer
Printing as if running out of toner
Why is my printer printing so light. The black is coming out as if i ran out of ink even with a full cartariage
  • 2 more comments
  • john L C Sep 29, 2008
    Mr. Lopez
    where is the toner save on button? I am not too familiar with that button.
  • piddledid Oct 06, 2008
    I'm having the same problem...I can't find system settings under menu, only system set up and there is nothing similar to toner save under that setting or any other that I've found. HELP!
  • john L C Oct 08, 2008
    thanks for your help Mr. Lopez. I will make a call as soon as possible.
  • KKMARINO Oct 10, 2008
    Entire Document prints fine accept one streak about 1/4 of the way into a document. It is a light streak down the whole document. DO the heads need cleaned. What can i do to fix this...Machine is 1 year old...
  • 161 Answers
There are various possibilities:
1. Toner Save on - turn off the toner save button and try again.
2. Reset the unit - go into [MENU], [OK], right arrow until [SYSTEM SETTINGS], [OK], right arrow until [CLEAR ALL MEMORY], [OK]. You may need to reprogram some settings.
3. Your laser unit is bad - this is very rare and if the case, you need to take it to Authorized Service, for that part requires much dissasembly.
Posted on Sep 29, 2008
  • Felix Lopez
    Felix Lopez Oct 01, 2008
    Sorry about the Toner Save button, your model doesn't have one. What it does have is a Service Bulletin from Samsung to all Authorized Service Centers (ASC's) explaining an issue with the black toner cartridge. Apparently, the black toner creates an adherence that affects print quality. Samsung has issued specific instructions so all Service Centers can fix the problem Call 1-800-SAMSUNG and navigate to the printers section. Explain your issue to the service rep and ask for a Service Ticket Number and your closest ASC. This is very important, for no ASC will work on the unit without that authorization number. When speaking to the ASC, you may refer to Service Bulleting No. 2008-CLP-001.
    Be blessed.
Why replace yellow toner
Most printers won't run without a full set of cartridges each with ink to print. This ensures that you spend on cartridges even if you are happy to use just black for a while.
Nov 30, 2014 | Office Equipment & Supplies
Tip
Brother HL-2140 does not print even if toner is full
In the Brother HL-2140 printer, it shows the Toner led light is on. Even if there is plenty of toner on the cartridge. It just wont print anything after initiating a print job since the toner light is on.Here is a trick on what you need to do:
1. Turn off the Brother HL-2140 printer.
2. Open the front access door to take out the toner from the carriage.
3. Notice that on both sides of the toner, you will see a small hole which is most probably the sensor.
4. What you do is to cover the sensor holes with masking tape and color the tape with black marker. Or, you can also use an electrical tape to cover them.
5. Shake the toner so that the ink inside will redistribute evenly.
6. Return the toner to the carriage and try to initiate a print again.
That's it!
on Jan 13, 2010 | Office Equipment & Supplies
How to check if the ink is ran out from hp
If you have full installed HP program that came with Printer then you can find Ink Level using HPTool Box utility.
another way is find out is that if your prints are comming light then its time to refill or buy new toner.
Third way is to judge by Toner weight. if low weight means also there is low ink.
Mar 20, 2010 | HP LaserJet 4300 Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
How to convert the color printer to Black?
No,sorry. Even if the print looks like it should use black toner only,it uses a little of color toner depending on the shade .
This is also true for other laserjets and inkjets
Hope this helps
Mar 31, 2008 | HP Color LaserJet 3500 Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Printer
I had same problem it wont print with just black even by using the settings.You can trick it into thinking the color cartridge are full by taking out the color cartridge and taping over the clear part of the cartridge were you can see the level of ink.Thats how the machine knows weather or not the ink is full by looking through the glass by either light or some other way and if its blocked it thinks its full.
Sep 05, 2007 | Office Equipment & Supplies
Samsung CLX 3160fn All-In-One Printer Logo
210 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
