Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
DC power input intermittent, inconsistent connection and charging
Seems like the power to the XM2go is very flaky - can't tell what the source of the problem is;
Symptom - the charging + sign turns on an off. More often off, and the battery runs does and then it shuts off. This is not a loose connection - it goes on and off when it is sitting still when it sitting still on the shelf. But stranger than that - this happens when the reciever is in the home cradle and the car cradle, and when the dc power input from an AC source if plugged directly into the bottom of the receiver, but not when I plug the cigarette lighter power cord input directly into the bottom of the receiver when in the car. (Not a great solution however, because I can't plug in the antenna to the receiver directly, and as we all know, the portable antenna is worthless).
This problem first appeared in the home crade. I thought this might be a problem with the cradle, and was able to instead plug all inputs into the car cradle and use in it my house as well as the car. But then the same problem developed on the car cradle. I got a new XM2Go from a relative who never activated his, and tried replacing all accessories on the old XM2go -- it appears not to be caused by either the battery, the cradles, or the converter inputs.
This has a black battery in it - which is what I think was the newer replacement battery, for what that is worth.
Any ideas what the issue is?
  • 5 more comments
  • JSHarper1 Sep 27, 2008
    When I said I tried swapping out all accessories with the new (and functional) XM2go, that included swapping in the new battery from the other unit - did not help. So I did not think it was worth purchasing a new battery. Also, given the price of a battery, I can get a newer model XM receiver.
    I had already swapped the old battery with a new battery from the other XM2go that I got, and that did not solve the problem.
    I don't think its the charging pin - that solution seems eliminated by the fact that when I plug the DC input from the car cigarette lighter directly into the bottom of the receiver, not using the car cradle, the problem does not occur. That is why I initially thought the problem was in the cradle.
    See earlier comments - direct connection to DC input from car to bottom of receiver (without cradle) maintains a good connection and the receiver takes a charge, so does not seem to be a problem with the input pin.
  • JSHarper1 Sep 28, 2008
    I don't think this is a cradle problem - the problem exists in all three cradles that I have (2 home cradles and one car cradle). I also think it occurred with the other cradle I had (but can't retest, because that was stolen from my car with the newer XM2Go that I had.)
    Here is my theory - The reason it works in the car with the DC cord plugged directly to the bottom of the receiver is that there is something about the shape of that cord plug that allows the pin to fit more securely when directly plugged in than when in the cradle. The configuration of all cradles may be such that the pin does not go in as deep, or tight, or something, and make a good connection.
    I think that the second proposed solution (problem with receptor socket pin is the closest), but I think no cigar. Reason is that (a) it's out of warranty, and (b) it's not an electronic problem.
    Here is what I think I need from the experts -- in retesting, I have discovered that in the home cradle if I pull the top of the receiver forward, it will make a connection and charge (the plus sign comes on the battery on the screen) -- that is harder to do in the car cradle because it is in so tight. I think this is a wear and tear problem with the pin receptical(s) in the bottom of the receiver caused by frequent reinsertions in the cradles.
    So here is what I need from you experts -Can anyone advise on taking apart the XM2go and accessing the base receipticals from inside the case so that I can examine and tighten the receptical so that the receiver does not have to be pulled/jammed forward in the cradle to make a good connection?
    Since these receivers are made to be portable and move from cradle to cradle, if I am right, I am surprised that this is not a constantly recurring problem with the XM2Go (and probably other XM receivers). [I have an original SkyFi that seemed to develop the same problem, that I gave up for dead - I'm going to go back and test this receptical theory as well on it.]
    I need a DIY solution if one exists, because (a) I don't find anyone who purports to repair these receivers, and (b) the bench fee is probably more than a replacement.
    To solution 1:
    I have had several suggestions from experts and the comments reflect responses to their comments (which apparently do no show up). You have listed all the "usual suspects" - what I was hoping to find was a recognition of a common problem with a well known solution. I do think that it is physical problem, not electronic, and probably due to weak attachment of the recepticals at the base of the receiver.
    By the way, on a short check of the internet, I really did not see anyone repairing these receivers, or purporting to have expertise in them. I rather doubt the bench fee at a nonspecialized repair service would be worth the price of the unit.
  • JSHarper1 Oct 26, 2008
    After a month of experience, I am confident that the problem is with the receptical at the bottom of the XM2go -- I am able to get it to reliably connect to power through the cradles by (a) in the home cradle, putting a heavy object behind the receiver to force it forward in the base so it makes a good connection, and (b) in the car cradle, wedging a couple of pennies between the cradle and back of the receive to force it foward in the cradle. Any DIY suggestions of how to open up the receiver and fix the reptical allignment?
    So - guesses as to bad battery, oxide on plugs were not valid solutions.
  • 2,071 Answers
Battery is new ,charging pins is tight and good connection then. Intermittent, inconsistent,problem this caused by circuit board trouble,needs to reworks the solder joint of all the ICs there,by using a hot air. This common problem of this kind of unit..
Hope this may help you;
Regards,
VOTIT
Posted on Sep 28, 2008
    Master:
  • 479 Answers
Get the device checked at the very local repair /service center so they can give u the proper estimate to get it repaired.as per your comments given till now its necessary to check the parts 1 by 1 and for that you will have to buy the parts.but in that repair center they will have all the necessary parts in spare so that they can temprory replace the parts and check where the problem lies exactly.
as its the ON/OFF problem it could be because of several reasons
1)loose connection somewhere in the wires of the device.
2)battery problem.
3)device internally got a circuit breakage where the charging connector is fitted. so soldering needed compulsory to make it work.
4)cradle problem.so reparing or replacement needed.
5)then it could be the problem of charging pin in the receiver.
6)it could also because of moisture or dust setteled in the device or on its connection.blowing hot air through hair dryer could also help.
and this all the doubtful problems can be checked more properly on site with the device in front so get it checked first to get the perfect estimate as sometimes its just the problem of servicing and cleaning the device and we just go on replacing the parts.
Posted on Sep 27, 2008
  • 6,487 Answers
This is only a problem with teh cradle because base from what you inform us you already isolated the problem and it now leads to the cradle's problem....
  • Mark Gil
    Mark Gil Sep 28, 2008
    You can try to contact Delphi at 1.877.GO.DELPHI (1.877.463.3574).
  • 65 Answers
I think that there is no problem with the battery... there is a problem in the charging pin of the receiver... if the charging pin is not in proper condition then it wont charge the receiver properly.... so better contact the manufacturer and replace the receiver if its under the warranty period...
  • navidh
    navidh Sep 27, 2008
    better change the cradle... i think only that can fix your trouble now
  • 19,396 Answers
Try replacing the battey.
You find battery here:
Pioneer XM2go MP3 & MP4 & PMP Battery ... $19.00 - Gizmos2Go XM2go Replacement Battery for Inno/Helix $24.98 - XMFanStore.com PIONEER XM2go Battery $31.00 - e-laptop-battery.com
  • 1 more comment
  • Ginko
    Ginko Sep 27, 2008
    If it is charging regularly on car charger, it is possible that is the cradle, or the power adapter, that's right. If it does not go well even when battery is charged on car, then the battery is also defective.
    Here is the cradle: XM2go Home Cradle for Tao XM2go
    And this is the entire home adaptor kit, with wires and power adapter.
    The powwer adapter must read approximatively 5V, here is the replacement 5-Volt Belkin Home Power Supply or 5-Volt Home Power Supply
  • Ginko
    Ginko Sep 27, 2008
    If the charging turns off and on , it is likely to be the cradle. Test the power adapter with a multimeter.
    If power adapter is OK then is the contact in the cradle.
    Check also if there is oxide on the connectors in the cradle.
    Ensure that power adapter connector is not faulty, if it is ok replace cradle here Home Cradle for Tao XM2go.
  • Ginko
    Ginko Sep 28, 2008
    Thanks for the update.
    If it happens on the three cradles, and power is intermittent, then the problem is the socket at the base of the receiver.
    Check if the socket is dirty or has oxide. If there is oxide remove it with circuit cleaning solution, you can buy it at any Circutcity shop.
    If you do not notice anything abnormal, it is one of the contacts behind the socket, this can be fixed by a good phone repairer, or any good electronic repairman.
With the Uniden UH7700NB How do I tell which is positive and negative on the power input THANK YOU
You can connect the radio to any standard 12 volt DC power source, with either a positive or negative ground. If you don't know whether your power supply uses a positive or negative ground, consult the manual for your power supply or contact the manufacturer.
Jan 10, 2017 | Car Audio & Video
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
Lorex mc6996 4 wires connect to what? red, white, yellow, bare copper wires
Call Lorex
1-888-425-6739
Otherwise it appears this is 24V DC camera that requires DC transformer.
Photos of the product show plug-in connections.
That seems inconsistent with description, implying that incorrect model number was given, or this is a used product that was taken apart?
Add a comment.
Attach a photo.
Apr 19, 2013 | Hardware & Accessories
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
I have Acer Laptop with a JV50PU motherboard which has a faulty DC input socket connection. The laptop works OK on Charged battery but not on DC input. Is it possible to get a schematic of the motherb
If the DC Power Jack is soldered onto the motherboard then take the time to unsolder it and remove it. Then buy another DC Power Jack which costs less than $8.00 and solder it into it's place. Normally when it is soldered onto the motherboard there is no cable involved. That's all there is to it if it's soldered onto the motherboard.
If it sits on a slot in the motherboard and has a cable harness attached to it then you can purchase that too for less than $15.00. All you do then is follow where the other end of the cable harness plugs into the motherboard and unplug it. Then place the new dc jack in the slot where the old one sat and plug the other end of the cable harness into the motherboard.
Mar 20, 2012 | Computers & Internet
I have a Yamaha IM8. I had a condenser mic hooked into channel one with phantom power on. I had to leave the room for a while and when I came back, I noticed some rather severe popping in the audio. I turn...
There is really no way for a condenser mic to damage the board UNLESS you break the ground and get a static discharge into the input. That can happen with any microphone and has NOTHING to do with the phantom being on or off. As phantom power goes on and off slight bias at the input preamps can make amps non-linear causing the raspy sound you heard. The Phantom LED means NOTHING as it shows the state of the phantom switch by connecting a 12 volt source through a resistor to the LED... It shows NOTHING regarding the state of the 48 volt supply. Each input circuit has two 6.8Kohm resistors to the swinger of the phantom switch 2nd pole that either grounds those or connects them to a filtered 48 volt source. As long as you don't have a static buildup there is NO need to turn phantom power on or off while connecting a condenser microphone. At each input when using the XLR jacks are two per side 470pf capacitors for RF bypass. For the XLR's there is a 10Kohm between the signal lines and two series 10mfd/50 volt caps in series of each input to block the DC, when using phantom power, from reaching the preamp stage. These caps have to charge and discharge when changing the state of phantom power so you should AVOID having the main amps being driven while changing the state of any phantom power. Always have the fader(s) down and any monitors down to avoid a thump and also the non-linear raspy transition as the input caps charge/discharge. So fix the microphone... don't know what type you have, but DO check the cable (first) as ALL three conductors MUST be good for a condenser mic to work on phantom power. A ground leakage or noisy connection will cause your symptoms. Use a SHORT known good cable right at the board to test the mic. The 48 volts is applied through the two 6.8K resistors between both the signal lines to the shield of your XLR cable. The microphone picks off the 48 volts with a similar circuit.
Now let's cover a very important thing regarding system safety: ALL, and I do mean ALL interconnected equipment MUST be powered from the same source. Professionals run a power cord back to their mixer right alongside the snake. This is to avoid ground bounce damage due to bad building grounds or ground faults.
Mar 22, 2011 | Yamaha IM824 24 Channel Mixing Console IM8...
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
No power through 35 amp charge conttroller
Refer to the manual.
Do you have the correct setting for the Bulk load?
Open the cover and look.
Hope this tip helps.
r/
David
Feb 01, 2009 | Xantrex Technology Xantrex Charge...
Connecting intec gamecube screen
The Intec Gamecube screen requires both a 12 volt DC input and the AV input. The larger connection is the AV cable which plugs into the back of the Gamecube console. The smaller round cable is the 12 volt DC input cable that goes to the power source for your screen. The solution is to either get the original splitter cable that splits the DC power to the screen and the Gamecube, or use separate 12 v DC inputs for each device. These original Intec splitter cables are rare and are not cheap, and the only place I have found them for sale is at the NES Repair Shop:
http://nesrepairshop.com/online_shopping/index.php?productID=645
The only other solution is having separate 12 v input cables for the screen and the Gamecube. And finding the right size (very small) is also a task.
Jan 14, 2009 | Nintendo GameCube Console
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
215 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
