Channel setting for a 13 inch Orion TV--can't get it to stay on channel 3
We have an Orion TV (13 inch----Model TV1334C) that we're trying to hook up to use with a digital TV converter box. When we try to put it on channel 3 in order to use the box, it won't stay on that channel. We've tried punching the number 3 and also using the add/delete channel feature. No matter which one we use, as soon as we get it, it immediately changes to a red "del" and deletes it!! How can we get it to stay on 3? This TV was previously our son's, and he said that he remembered that you had to "set" it some way to get it to work. The manual is lost. Any idea how to get this to work? We're enjoying beautiful digital TV on another set---no problem getting it hooked up and going, but this Orion TV is proving to be quite a challenge!! Thank you for any help you can offer!!
  • 275 Answers
SOURCE: can't get any tv reception
How do you expect a picture, without any Signal input? Just get any Rabbit Ears Indoor Antenna. Ore, if u wanna first try out, just push a length of Electrical Wire approximately 3-4 feet long into the Antenna socket at the rear of the TV, and then do Auto search. You will be able to view a few local channels - tho a little grainy. If u are satisfied, good, otherwise, then get an antenna.
Posted on Aug 18, 2006
  • 68 Answers
SOURCE: Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Posted on Oct 23, 2006
Bubbabear64
  • 2794 Answers
SOURCE: Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Posted on Aug 17, 2008
SOURCE: set up of tv
http://www.olevia.com
Posted on Aug 31, 2008
SOURCE: Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Posted on Feb 02, 2009
On an orion tv, how can i get channels after 13??
In the menu, find antenna/cable. Locate cable and program from there.
Dec 20, 2014 | Orion1934 19" TV
Sharp TV
Without the specific model number, I can't give you teh exact sequence, but you need to setup the set to only enable channel 3. Work your way through the menus to select channel 3 as your "favorite" channel. Disable all of the others. The set should then turn on as channel 3 at all times. Feel free to post the model number and I'll pass along more details.
Dan
Mar 20, 2008 | Televison & Video
External input
I'm not overly familiar with your brand, but generally there are 2 ways to get to the AV input.
1) Use the TV/Video button on the remote (if there is one)
2) Channel up or down from the last channel at the high or low end. In other words: channel down from channel 2 may bring you to the AV input.
Hope this helps,
Dan
Sep 23, 2008 | Orion Televison & Video
Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
Aug 17, 2008 | Orion1934 19" TV
Orion tv only has 2 channels and it's hooked up to cable
go to menu,go to were it says cable and air,select cable. then go up to auto program do search, this should do what you want.
Jun 13, 2008 | Orion Televison & Video
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Unable to get tv to aux screen
Try going down from channel 1 using the P/Prog/Ch - button on the set.
Feb 09, 2008 | Televison & Video
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
