TURN COMPUTER ON ON FOR 3 SECONDS THEN GOES OFF WHEN ON HARD DRIVE LIGHT IS ON BUT NO NOUISE FROM HARD DRIVE
  • 661 Answers
Sounds like a Power supply failure to me, this is a common symptom of a failed power supply
Posted on Sep 27, 2008
Maxtor basics 500GB external hard drive not working
Every time you turn your computer on it is going to "spin up" and the light is going to come on. Just because the light goes out and it idles so that you can't hear it anymore doesn't mean it isn't still on. It is. You can verify this by using windows explorer to view it and its files.
Jun 29, 2012 | Maxtor BASICS Personal Storage 3200...
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
When I turn on my computer the monitor turns on for about 3-5 seconds and then goes black. The blue light stays on and does not blink. If I turn the monitor off then back on it will again show the screen...
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust in its socket
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this help you
Aug 28, 2011 | Computers & Internet
My monitor is a dell 2000 flat screen 20.1" turns on but after a couple of seconds it goes black and if i turn it off then back on it shows for a few more seconds before it goes black again the power...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 18, 2011 | Computers & Internet
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
When I turn on my PC Windows starts fir 4 seconds then I see on flat monitor LG "Analog Power Saving Mode" and LG monitor goes off (yellow light on monitor panel). Please help.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 11, 2010 | LG Computers & Internet
My playstation wont turn on the red light shows and then i turn it on the light goes green and then a few seconds later goes back to red and shuts down again whats the problem?
Last person I knew that had this problem, I fixed it. Although he did lose all his save games... The OS software was corrupt. Here's what I did to fix it:
1. Remove the hard drive and plug it into a computer that has a SATA connector on it's motherboard.
2. Format the hard drive, any format will do.
3. Download the latest update from Sony and save it to PS3\UPDATE folder on a flash drive.
4. Reinstall the hard drive into your PS3 and allow it to reformat it. Turn off system after format is complete.
5. Insert flash drive into USB port on PS3. Proceed with update.
6. Restart system after update is complete, and enjoy all over again! =)
I'm sure if you really wanted your save games, there has to be an emulator out there somewhere, but then I don't know how you'd get it back on your hard drive after all is fixed... Honestly, lost save games is better than no PS3 at all...Hope this helps you and many others that had this same problem! =)
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
Help... Acer Aspire 3690 laptop.
My dear friend as I told you that you should change your RAMs it will b ok give me your response on jazib_qurashi2000@yahoo.com
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
External Hard Drive doesn't work
There is a (laptop-size) hard-drive inside the case, and that hard-drive is failing. As it spins, it generates those noises, like a dying dinosaur. If it still is under warranty, exercise the warranty, and replace it. If the warranty has expired, tough luck.
May 21, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
A135 S2386 black screen
black screen with a orange light on cd drive hard drive light for a few seconds and goes off
Lubos
Aug 05, 2008 | Acer Aspire 5315 Notebook
Open Questions:
@#$@Free1'877'778'89'69Avira Antivirus Support Helpline Number? USA 1-877-778-89-69 Avira Antivirus Support Helpline number is straightforward to use. Avira Antivirus Support phone number is open twenty four hours daily and seven days per week.Avira Antivirus support Helpline Number's agent will assist you with remote help.Avira Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are Avira Antivirus SupportUSA.A single call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number.
May 29, 2017 | Avira Computers & Internet
Computers & Internet Logo
75 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
