Question about Cyberhome CH-LCTV 150 15 in. LCD Television
The TV will not power on with remote or manual button
I purchased 2 years ago a 15 inch LCD from Target and it worked fine but now the AC/DC power supply cord has this annoying popping noise and it will not power on. I have unplugged every plug possible and sometimes it will power on after the annoying popping noise from the supply cord. Is it possible that the plug is faulty or is it time for a new TV? Thanks so much for your prompt attention to this matter.
Respectfully Yours,
jlmmaestro@hotmail.com
  • 223 Answers
Have you had any major power outages in the days leading up to this issue? It could be a power source, cable or outlet. Try different outlets if you can and see the tv responds.
Best of luck,
Al
Posted on Apr 18, 2017
I awoke this morning to find the sound on my Apex Digital LD4088 LCD tv is dead. The picture is fine, but sound is dead, how do I solve this?
Download the user manual to your TV. Clik here to download it. See whether audio options to it are set right. If all are right, check its speaker. If speaker is OK, the audio output circuit section should be troubleshooted.
If you feel any difficulty in downloading the manual, send your email address to me. I'll send a copy of it to you by return mail.
May 16, 2012 | Apex Digital LD4088 LCD TV
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
Remote does not work, tv is fine
Found universal replacement remote for Viewsonic N2750 at Target for $15. Works perfectly. it's the Sony RM-V310A. Tried all 5 remotes from Walmart, none worked even though it said would work on back of packaging..Target has about 5 Remotes only this one worked. My original remote died after 2 years. ordered an original replacement. that one died after 2 years. They're ****.Manufacturer discontinued it. found one online for $50. Just get the Sony RM-V310A at target.
Oct 14, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
I purchased my tv 2 years ago. Watched it
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Missing Manual
I found the manual on the Target website. Now I just need to find a remote that will work with the TV. cheers
Oct 07, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Magnavox 15 inch lcd hdtv
the typical power cord is usually the same kind that is plugged into your monitor right in front of you. Buy another one of those. A universal remote should work (not promising anything)
Feb 12, 2008 | Philips Magnavox 27MS343S 27" TV
15-inch Phillips LCD FlatTV
It could be the AC adapter. That is easy enough to check with a DMM. Turn on the meter, set to volts dc, push red probe into the hole in the output power jack and touch the black probe to the outside of the same jack. Have someone plug the AC cord into a good outlet(one you know has power). If the adapter is working you should see 12 vdc displayed on the meter. There still could be a problem as I recently found an adapter which displayed the correct voltage with no load but little or no voltage with a load. Testing with a load is a problem if you are not familiar with the procedure. Odds are if you have 12 vdc the adapter is fine and you have a short somewhere in the monitor. If you are handy with tools and feel confident, remove the back of the unit and check the fuses in the power supply. If they check OK you probably can't do much more. Unless you are an electronic tech you will need to take the unit to a shop for repair by a qualified tech. Good luck.
May 30, 2006 | Philips 15PF9925 15 in. LCD EDTV
Cyberhome CH-LCTV 150 15 in. LCD Television Logo
49 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
