No signal input
Computer froze.sent error, answer came back missing accelator driver. while trying to find it computer froze again. i turned computer back on and monitor says no signal input. I have checked connections and they are fine.
  • 661 Answers
This sounds like fried graphics card... the clue being the error message before it died,
Does the PC boot so that you can see the Bios Screen, (the very first info that displays) the BIOS screen does not use the windows drivers and would be unaffected if a driver failure occurs,
if this is the case then press f8 on boot to select SAFE mode so you can remove/replace the graphics drivers (in device manager)
if you cannot get bios or safe mode, then try reseating your graphics card first as it may have just worked it way out of its slot (due to expansion of card/slot as system heats/cools)
if this fails to work then a replacement of the graphics card is probably what is required.
Posted on Sep 27, 2008
How do I get out of no input signal
Hello
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
I have HP Compaq Presario V2000. Last week I was in the middle of an email and the keyboard froze. I turned of the computer using the power button and of course when I turned it back on I received the...
Best I can think is use a usb keyboard to get online with it and use a program such as Driver Detective to scan and see if your missing some drivers or if MS (this is common) updated to an invalid driver.
Jul 11, 2010 | Computers & Internet
My monitor gets no input signal, computer does
Try the montor on the external vga connection of the laptop. You can swap the signal from the laptop screen to the external monitor using the swap key (usually a FN key). You can do this whilst the laptop is up and running. If you see the display there, then you know the monitor is o.k. Then check the connection to the PC. If it is a card (PCI/AGP) make sure the card is properly seated. If you don't see display on either check the pins on the monitor plug if any are bent or missing. Sometimes these pins can be accidentaly pushed back into the plug housing. You can retrieve them with small long-nosed pliers.
Sep 16, 2009 | Xerox XA7-17i 17" LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Computer will not boot up
need to reinstall windows it is corrupted
Mar 27, 2009 | Dell Dimension 2400 PC Desktop
No input signal
Hi, there is a posibility that the issue is caused by your system unit. NO INPUT SIGNAL occurs when system unit fails to start properly. One possible reason is the power good signal was not sent back by power supply to mother board. You can check for any shorts or grounded device in your system unit. If you can reseat all the cables (power cable, IDE cable), expansion cards, memory cards even microprocessor that will be good. Another thing you can try is to power cycle your computer. If you are not confident enough to do those stuff you can call your computer vendor and ask for assistance.
Tirzo
Jun 13, 2008 | Acer Aspire L310 (ASL310UD631A) PC...
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
