Question about Dryers
Loud noise when dryer runs
Very loud noise when dryer runs
  • 1 more comment
  • drusslpn91 Sep 28, 2008
    sounds kind of like a very loud rattling sound. "dadadadadadada"
  • J. May May 11, 2010
    I know a thing or two about working on dryers; what kind of noise?
  • Anonymous Mar 13, 2014
    loud noise when carbrio 6400 dryer is running
    Scholar:
  • 76 Answers
I agree with the reply where it could be a bearing or the belt tensioner pulley. Although typically the rear bearing will make a squealing or squeaking sound. There isn't too much that can cause noise in the drum itself. I have seen dryers where the belt was frayed or about to go make the noise you describe. I don't think it is the rear bearing, but the front glides, or bearings could be going out causing the dryer to run unbalanced.
Posted on Sep 29, 2008
    Novelist:
    Champion:
  • 261 Answers
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Posted on Sep 28, 2008
  • John Robbins
    John Robbins Sep 29, 2008
    This is so true thanks try for the info. We can never be a know it all and I will hone the blade every chance I can. As it was a generic issue I went with the common two, That sound can also be caused by rollers along the back of the dryer and making this sound from contact with the drum. Kenmore has a recall on these bad boys because they used nylon to make them.
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Dryer makes loud noise
Probably a bad set of glides.
ea82af1.jpgor worse.Check out my BLOG on this
Posted on May 20, 2009
  • 254 Answers
SOURCE: loud noise while running
you are gonna have to get inside the unit to determine whats defective...
if you want a parts breakdown i would recomend going to sears. com clicking on the section parts and service usually upper right corner, then click parts, u should be in their parts direct section enter you model number which u can find when u open ur dryer door their should be a sticker or tag somewhere that will list it.. find ur model or sometin similiar uually last digits designate color so it doesnt matter. you can see how the unit comes apart or get prices or part numbers on specific parts.
I would personally check the operation for defectiveness on your belt,rollers, idler pully, and possibly a seal if yor dryer has sometype of glides or seal.. hope this helps
Posted on Feb 02, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
May 19, 2009 | Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Loud dryer noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfhgf
Dec 28, 2008 | GE Profile Prodigy DPSR513GA Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
571 people viewed this question
Top Dryers Experts
