Question about Texas Instruments TI-83 Plus Calculator
TI 83 Plus
I can't seem to graph anything on my calculator. Ex. y= 2X + 3. I get ERR. WINDOW RANGE QUIT. I don't know how to clear or change the window.
  • 30 Answers
Try hitting "ZOOM" then "0". This is for the "Zoom Fit" option. It will automatically adjust your window range to best fit your equation!
Posted on Sep 10, 2009
Try going to zoom and put in standard zoom should work. and u only need to put in 2x+3 not the y since it's already plugged in
Posted on Sep 24, 2009
Every time i press graph on my ti 83 plus it says ERR:Window Range 1:Range how do i solve this problem so i can graph
You will have to hit the window button on the face of the calculator that is just below the screen and change the values making sure the max value is larger than the min value.
May 02, 2011 | Texas Instruments TI-83 Plus Calculator
Every time i enter in something to graph like Y =5X-4 and i like graph my calculator says ERR:WINDOW PAGE 1:quit
There is no such error message from the TI 83PLUS. Did you mean WINDOW RANGE?
The easiest way to correct the messed up window dimensions is to reset them. You can press the Zoom button and select 6:ZStandard
Apr 26, 2011 | Texas Instruments TI-83 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
I'm trying to graph a circle on my TI-83 Plus. 1.) I don't know the way to trick the calculator into graphing the circle 2.) When I try to graph I get 'ERR:WINDOW RANGE' I don't want to use draw and i...
Here is the link to post where I show several ways to draw a circle. If you do not have the conics applications download and instakk it on the calculator.
You can also use the cabri Jr application downloadable from education.ti.com. This application is dedicated to geometry.
Apr 10, 2010 | Texas Instruments TI-83 Plus Calculator
ERR: WINDOW RANGE 1: QUIT
There's something wrong with your window limits, for example Xmax < Xmin or Ymax < Ymin. Press WINDOW to bring up the window editor and examine the values, making sure there are no inconsistencies.
If you don't see anything wrong, post a comment here listing all of the entries in the window editor.
Feb 19, 2010 | Texas Instruments TI-83 Plus Calculator
ERR: Window Range
Press ZOOM and select Zoom standard (ZoomStd).
Alternatively, press the WINDOW key to access the window range setup
Set Xmin=-10
Xmax=10
Ymin=-10
Ymax=10
These are the standard dimensions of the window.
You can change the dimensions as long as Xmin is less then Xmax, and Ymin is less than Ymax. Do not make Xres close to Xmax-Xmin.
Jan 10, 2010 | Texas Instruments TI-83 Plus Calculator
When i press Y= on my graphics calculator it shows ERR: INVALID
Press the 2nd key, then press the plus key then press 7, then 1, then 2. Your calculator will be reset and you should be able to graph the equation as long as y-intercept is between -10 and 10. If not, you'll need to change your window by typing in a new domain and range.
Aug 05, 2009 | Texas Instruments TI-83 Plus Calculator
Suddenly, the graph window reports ERR:UNDEFINED
Go to Window and make sure there are acceptable values for your graph, default is usually 10 and -10 with 1 scale.
Jul 06, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
253 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
