Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
Cleaning machine propt will not go away
The 'clean machine/machine ready' light won't go away even after going through the entire cleaning process twice. At the end of the cleaning cycle it says to 'press rinse' instead of 'empty grounds' like the manual says it should. After I hit the 'rinse' button, it immediately returns to the 'clean machin/machine ready' message. This same thing repeated after cleaning a second time. It also repeated after unplugging the unit for 12 hours.
I have the same machine and had the same issue all day yesterday. Tech support will tell you to clean the tamper (round disk behind the tan/gray "flap"), which you should do. That didn't do it for me, however, so I kept cleaning. I cleaned out the chute where coffee powder goes. Then, after turning off the machine and removing the tray, I used my fingers to go up/under/behind as much as I could get to. I found the motherload of old coffee grounds. It's hard to describe where, but it was all around that metal area in the center. Just keep poking, but use your fingers so you can feel where the coffee is. I tried q-tips, but that didn't work..you have to feel it. After I got all the gunk out, I ran a cleaning again - no tablet - and it no longer said "press rinse" at the end of the cycle. It asked me to dump the tray, and then it went to "ready"! Yahoo - saved a bundle in shipping and repair.
Posted on Aug 29, 2009
  • Tony Karavidas
    Tony Karavidas Apr 13, 2014
    I have an Impressa E8 and had this problem recently. I cleaned and cleaned like this messages says, and the problem finally went away! 5300+ cups and still going strong!
We have had this problem too. We found that once you change the filter and do the filter change routine then cleaning will clear the message...go figure!
Posted on Oct 08, 2008
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Wfs1072aw
try following this video it's on a bosch but basically the same
Jul 30, 2013 | Washing Machines
Red light keeps blinking
try changing the needle
rethread the machine top and bobbin
try turning the bobbin in the opposite direction
make sure the thread has not come off the thread take up lever
make sure all thread guides are used
make sure the thread is not caught around the spool pin
all so something could have happened to the motherboard
Dec 22, 2012 | Sewing Machines
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
Perform cleaning on EcoQuest Fresh Air won't go away after pushing reset button
If you did not thoroughly clean the contacts for the ozone plate, the "Perform Cleaning" light will not reset.
May 05, 2012 | Ecoquest Fresh Air Air Purifier
I can't get my Q to start properly. My start routine is to open the tank valve (20 Lb. with adapter hose) turn the control valve to start and hit the electronic start button. I get an immediate start at...
Yes, it does sound like a regulator problem or clogged burners, which causes delayed ignition.
let's start with the regulator first. Turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is fully open, light the burner(s) as you usually do. Does the burner light, all the way around? If so, you solved the problem. Always, turn the tank valve on very, very slowly.
If that didn't solve the problem, you burner needs to be removed and thoroughly cleaned, including the venturi valve at the open end of the burner. If it still doesn't light as it should, the regulator needs to be replaced. If necessary, you can purchase it directly from Weber.
Hope this helps you to troubleshoot and solve the problem. Happy Grilling!!
Apr 23, 2011 | Weber Q Grill
"clean" light will not go out
In my experience with this coffeemaker, the Special Cleaning Cycle light doesn't illuminate until the machine is very clogged up. The risk of ignoring this indicator and waiting too long to clean it is that by the time it does get cleaned the calcium deposits will end up clogging the check valve, thereby shutting down at once. Regular cleaning will prevent significant amounts of calcification and thereby result in hotter, better tasting coffee and less risk that the loosened mineral deposits will end up clogging vital parts of the machine if and when you do clean it.
If you notice, the inside of the lid to the water tank states that the unit should be cleaned every 30 days. This is true whether you see the cleaning indicator light illuminated or not. To clean the coffeemaker, you must add 20 oz of undiluted white vinegar per the owner's manual, then press the "clean" button. If you do not recall the last time the coffeemaker was cleaned and wish to start off on the conservative side, you may wish to use a diluted solution of white vinegar (about 1/3 to 2/3 water).
The coffeemaker will brew part of the vinegar, then pause 30 minutes, then restart itself. Use clear water to rinse at least two times after the process completes. This will take about an hour in all. If you are in a hurry, you can just run vinegar through a regular "Brew Now" cycle; however, this will be somewhat less effective.
When adding fresh, cool water to rinse the vinegar out, make sure to allow a few minutes to cool down between rinses because the element is extremely hot. You may wish to use a vessel other than the carafe to fill the water tank while rinsing because it will take less time. Otherwise, the carafe may crack or shatter if you take it off the hot plate and fill it with cool water straight away.
Finally, I suggest you visit MRCOFFEE.com and put the model number in their web search box. The Classic Edition Coffeemaker came in three varieties: MRX33 (black), MRX35 (brown) and MRX36 (red). The instructions are otherwise identical in operation and features. There will be a link at the bottom of the description to the user manual. If the model number no longer appears on their site, use your favorite search engine and type "model + manual + PDF" or terms to that effect.
Mar 29, 2009 | Mr. Coffee Classic 12-Cup Coffeemaker -...
Clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Sep 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
976 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
