Question about TechnoMarine Apnea 35mm Watch - Silver Dial, Two Gel Straps TMAXS05
Technomarine watch battery replacement
Cannot removed case back on technomarine chronograph watch
  • kab85225 Sep 29, 2008
    Thanks so much info was very helpful.
  • Anonymous Mar 14, 2014
    Technomarine chronograph second hand switch back to normal
  • 109 Answers
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
Just bought the watch, I set the time but the clock is not running. does it come with a battery? should I return it?
kindly check the lower sub dial if it is working. if yes, you don't have to worry because it is a chronograph. if not, check the crown if it is pushed down, if not, you got to push it, and if nothing happens you have to bring it back from the seller probably the problem is the battery. I hope i had been helped you.
Jul 27, 2011 | TechnoMarine NEO CLASSIC LADIES WATCH...
I was just given a black RSX 05 TechnoMarine chronograph watch, but the date is wrong. I can't seem to figure out how to fix it and I wasn't given an instruction book. How can I change the date?
your watch crown has 3 position. the normal position, the second position and the third position. pull it to the second position then turn it counter clockwise or vice versa. then push it to normal position if your done. i hope i had helped you..
Jul 10, 2011 | TechnoMarine Raft RSX05 Unisex Watch
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
Nov 05, 2010 | TechnoMarine Cruise Watch
I have a Techno Marine diving watch. It just stopped. How do I best replace the battery. Myself? Or do I need to send it somewhere? Cebron
Thank you for contacting FixYa.
NEVER attempt to replace a battery on a diving watch yourself. It will break the seal.
You will need to send back to Technomarine or take to a registered Technomarine service center.
You can find information here:
http://www.technomarine.com/Customer/Services.sls
Best regards! Jewel
Oct 05, 2010 | TechnoMarine RSQC11 Wrist Watch
I've lost the chronograph button above the winder. Where can I buy one on line and does it screw back in. Thanks. Edmond
mcdevito75, Best Bet with your Chrono watch is, check out a small watch repair shop in your area for that btton and replacement. A smaller watch repair shop may save you some money on costs.
Jun 22, 2010 | TechnoMarine Ceramique Watch TCB02C
Is it possible to change the battery on the Technomarine 10900 at home (with the proper tools) or do I need to get it to a repair centre?
It is possible. Open the watch case back, memorize all the writings on watch battery as well as how the battery is positioned (+ and -). Buy exactly the same battery, replace it and close the case back. To be sure case back is closed as tight as it was, draw fine line across the case and case back with non-permanent marker. This will help you align when closing the watch and you can clean it off later. Rate me, please.
Apr 26, 2010 | TechnoMarine RSQC11 Wrist Watch
I Have a problem with my Technomarine ABS05. There is changed a battery by someone. but the watch doesnt work. I removed the back and some oil came out. where can i find that sort of oil? How can I change...
Oil should not come out of a watch. There just isn't that much oil in a watch to have it dripping out.
Are you sure it wasn't water? I can see where moisture could have gotten inside the watch if it was not sealed properly after the battery change.
The fast mall battery change places, jewelers and mart stores do not hire people that are trained to change batteries properly. We have a love hate relationship with those places. We love them because they keep us in business with all the watches they damage. We hate that they are in the business of replacing batteries in the first place because of how many watches they damage.
If you had one of those cheap battery stores replace the battery most likely they did not reseal your watch and it got water inside. This water will cause the problems you have now with your watch.
You will need to have a qualified watchmaker repair your watch.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 16, 2010 | TechnoMarine Abyss ABS05 Watch for Men
WHAT TOOL DO I NEED TO REMOVE THE BACK OF FOSSIL BLUE #BQ-9232 AND HOW AVAILABLE ARE THE BATTERIES FOR REPLACEMENT?
Most watch backs either screw off with a special case opener that every wachmaker uses or pried off with a knife like case opener or sometimes a knife. Take this to your local watchmaker for battery replacement. Batteries are readily available but are a bit tricky to install properly and are best installed by a qualified watchmaker.
Nov 29, 2009 | Fossil Metal Chronograph White Dial ES1793...
How to change the hour
on most watches, you can change the hour by twisting the crown... As I can see this is a chronograph watch, mostly divers use these kinds of watches. the two other buttons are to set the chronograph. As i do not know what brand this is but, try to play with it you will find out. Or take it to a watch professional.
Jul 30, 2009 | TechnoMarine Dial Chronograph Watch
TechnoMarine Apnea 35mm Watch - Silver Dial, Two Gel Straps TMAXS05 Logo
2,684 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
