Question about Compaq Armada E500 Notebook
My computer shut down windows to prevent damage from my computer
Dear Pyrhyc,
I downloaded recording studio software onto my Compaq Armada E500 Pc Notebook, and about a week later im not to sure what happened but everytime i start the Pc up it says a problem has been detected and windows has been shut down to prevent damage to your computer
CONFIG_LIST_FALIED
Technical information:
(then theres a code)
then it says beginning dump of physical memory
physical memory dump complete.
contact your system administrator or technical support group for further assistance.
then it give directions on how to uninstal new hardware or software by clicking on safe mode at the menu screen, but every time i follow those directions it sends me straight back to the screen.
can you help me please
  • fruitcake101 Mar 30, 2009
    whenever i boot from a bootable cd it says windows is shutting down to prevent damage, how do i fix this issue? Does that mean that the harddrive is bad?
Receiving massage on my compu
ter saying window has shut down to prevent damage, how can i fix this
Posted on Jan 20, 2010
Plz tell me how to slove my problem
when i boot bootable CD sart loading files, then message error!
windiws has been shutdown to prevent damage
Posted on Feb 16, 2009
  • Compaq Master
  • 5,568 Answers
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Posted on Oct 11, 2008
4 Suggested Answers
  • 207 Answers
SOURCE: computer wont turn on
When you end up with a registry corruption, you are limited to what you can do. First thing I would try is this. When you power your system on and immediately after the POST boot, begin pressing F8 on your keyboard. This will bring up a Windows Boot Menu. One of the choices you will see if, "Last known Good Configuration..." If an install of software is what corrupted your registry, this should hopefully undo that. If you are experiencing hard drive failure, this will probably not fix that.
If last known good configuration does not work, I'm afraid that the only other solution is going to try and do a parallel installation of Windows so that you can save your existing data.
What Operating System are you using?
Here's microsoft's official description of your stop error:
http://support.microsoft.com/kb/830084
Posted on Apr 21, 2009
jaye_ellen
  • 591 Answers
SOURCE: will not boot up past the message I describe below
You might reload your Operating System to correct this. Insert your Recovery disk into your drive, choose DVD as Boot Option, recover your OS.
Posted on Nov 22, 2009
SOURCE: it has a blue screen
your windows OS is corrupted, you have to reinstall everything from the scratch. Doing a windows repair will not fix it.
Posted on Mar 03, 2011
What is the port number for the 9 pin serial connection. If greater than 2 how do I designate it as 1 or 2. Compaq Armada E500 laptop.
I've found it is highly unlikely to run an old DOS program in Win2000 so I have decided to setup an old computer with Win 3.1 and use it for my DOS software.
Jan 26, 2010 | Compaq Armada E500 Notebook
No drivers
Here below follows the original driver download page from HP:
Compaq Armada e500 Notebook PC - Download drivers and software .
May 19, 2009 | Compaq Computers & Internet
Windows 98 se, xp not installed to compaq armada E500 pc notebook
First, format the hard drive and make sure it is in FAT or FAT32 for Windows 98 install. Then do your partitioning etc and should work. If it doesn't, it is possibly a hardware fault.
Here is the site for the drivers for the laptop :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=1093
Hope this helps in some way :)
Jan 05, 2009 | Compaq Armada E500 Notebook
Compaq Armada E500
your product key may be on a sticker on the bottom of your laptop.
Aug 27, 2008 | Compaq Armada E500 Notebook
Acer aspire 5050 system not found
I think your boot record (Master Boot Record) is damaged and this can come from Windows just trashing itself as it is prone to do, or the hard drive has failed. That message is generated by the BIOS.
If you are running XP, this MS page will guide you:
http://support.microsoft.com/kb/314058
Aug 09, 2008 | Compaq Armada E500 Notebook
How do i unlock my compaq armada e500?
I JUST LET IT SET AND IT FINALLY SHUT DOWN ON ITS OWN AND WILL NOW POWER UP.
Mar 14, 2008 | Compaq Armada E500 Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada e500 won?t recognize the cd drive
Simple things first: Assuming the CD drive is removable, remove it from the laptop then re-iinsert it making sure it's pushed home properly so that the connectors seat properly.
If, again, the drive is in a bay (i.e. it's removable) then it may be the connectors are worn/damaged. If it's the drive connector then it may be repairable or you might pick up another drive, perhaps on eBay. It may also be that the drive has simply given up the ghost - so back to eBay :) If the connectors on the laptop have got damaged then you're looking at dismantling the laptop to repair/replace them, if that's possible.
If it's an external drive then the advice is very similar - check out the connectors first. If they look OK then you probably have to suspect the drive itself.
For either type of drive, there is always the small chance that the IDE controller channel on the motherboard has died - I have seen this happen in rare cases. Your options then are a bit limited. IIRC, that PC has no USB2 and even if it did, it wouldn't boot from a USB CD. You can get a PCMCIA interface card (now called simply PC interface) for an external CD. Depending on the card-drive interface, you might be able to boot from that.
If you need to install software onto the machine & have another (desktop) PC to hand: remove the disc from the E500, get a 2 1/2 to 3 1/2" disc adapter & temporarily attach the drive to the desktop as a secondary (i.e. not boot) disc. You can then load software onto the drive although you can't do a Windows install that way. If the machine already has an old version of windows on it, you can copy for example, the XP install files onto the drive, put it back in the machine & run an upgrade. Not the most desirable result but may be OK.
Nov 03, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
1,055 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
