No Power to Polk PSW650 Sub. Fuse okay. Main transformer primary open, looking for a replacement transformer. # on top 54-0013-0000
5 Suggested Answers
  • 4 Answers
SOURCE: Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Posted on Mar 07, 2008
  • 4234 Answers
SOURCE: Have a nearly 30-year old
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Posted on Apr 08, 2008
tech240
  • 169 Answers
SOURCE: the power transformer thermal fuse
Very poor cooling could cause this to happen althiough it is unlikely unless the transformer was really cheap and not designed for 100% duty. Severe overdriving combined with poor cooling could do it.
Most likely is .....
Internal short in the winding or a short circuit rectifier on the low side, either way the only way to correctly check the fault is with a variac and some test kit.
Hope this helps
Thanks for using FixYa
Posted on Aug 17, 2010
  • 55 Answers
SOURCE: Amplifier is dead. Relay in
it is in auto protect mode, something wrong with your transistor/ic
Posted on Sep 22, 2010
What type a fuse do I use for my Psw 125 power sub
Is this a Polk PSW 125? I'd contact Polk customer service.
Here is the manual http://www.polkaudio.com/Media/POLK/Product%20Manuals/PSW110_125_MN.pdf
There is some discussion here http://forum.polkaudio.com/discussion/77264/psw125-blown-fuse
A blown fuse indicates something wrong. I'd contact Polk.
Nov 17, 2015 | Audio Players & Recorders
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Gem sound 1300 watts pro 480 won't turn on
The main fuse has blown, or the power transformer has a open primary, one or too audio outputs semiconductors have shorted. To narrow it down the top needs to be removed and unplugged, set digital meter to ohms and check fuses, next! the too wires going into the transformer should have a low reading, but if it reads infinity or open the primary side of the transformer is open.
Jul 08, 2012 | Gem Sound Audio Players & Recorders
Rx dt707 is dead no power
The main fuse is open, or the power transformer has a open primary. Remove top and unplug system, if you have a digital meter set it to ohms and check the fuses, next put meter test leads on the too wires going into the transformer, if no reading it is open.
Jul 01, 2012 | Audio Players & Recorders
1501 sub will not power up. i opened, inpected and replaced power fuse 250v 6.3 amps replaced with same fuse and it blew as well immediately. what to do and how. I have some technical experience.
Isolate and look for possible shorted components.
Isolate the main power transformer from the board, and see if the
fuse still blow.
If it doesnt , then the rectifier and capacitors to the regulators.
But don't forget to check for possible shorted transistor
Sep 23, 2011 | Mackie SWA1501 Subwoofer
MTX Lolita Sub amp defective power transformer (open primary) What's the transformer voltage?
Without Knowing the Output Chip or transistor Numbers, I don't know but Most 100 Watt anps use 60 to 70 Volt Centertap Sacondarys. Also if You Take the Cover off The Transformer you will find a Thermal Fuse in the Primary. I have bypassed the Thermal Fuse and went with a external fuse, Go for it.
Oct 07, 2010 | MTX LOLITA 8" 100 WATT LOW PROFILE...
Microven doesn't work.
same problem here.
I just unmounted it and checked.
Main things you'd better check (if able, otherwise contact assistance..) :
- UNPLUG POWER
- Unmount, open the top (5 screws)
- microven fuse (open the top, standing in front look right top corner, there's a small circuit with wires and a black plastic case with a 250V 8A fuse in it): check it's ok
- microven transformer: it's the big one on the rear top, you need to check primary and secondary wires for short circuit (that's why the fuse blows up in case)
- magnetron: if both previous ones are ok, check (I can't say how except for getting a new one and trying..) and eventually replace the broken one.
Hope this helps
Sep 29, 2010 | Smeg S201X Electric Single Oven
My polk psw404 has no power, I check the fuse at power source
Could be the power supply but the transformer may
have opened up due to a "surge". Might have to contact Polk to see whats up and/or dealer as the
amp may need sent in for repair!
May 24, 2010 | Polk Audio PSW404 Subwoofer
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
123 people viewed this question
 Grubhead
Grubhead
