Question about Panasonic Workio DP-4530 Copier
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
  • Paul Homuth
    Paul Homuth May 11, 2010
    what error code are you getting on the screen when this happens
  • Anonymous Mar 14, 2014
    find the problem
    Problem Solver:
  • 18 Answers
First try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Posted on Nov 27, 2008
Panasonic Workio DP-8060 j50 problem
Check/replace the three exit and inverter actuatiors part #'s dzkl000047/48/49. Make sure inverter guides are tight. If persists replace inverter solenoid part #dzgb000033.
Jun 19, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
E4 02 error code
Paper Jam Causes 1. Paper Jam in Fuser Unit. 2. Paper Exit Sensor clear and close the front cover
Jan 10, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
PANASONIC DP-C262 COPIER IS SAYING THERE IS STILL A PAPER JAM AFTER IT HAS ALL BEEN CLEARED
the diagram will show where it is but refer to user manual. if no paper then a sensor has become dislodged and will need to be reseated
Jan 09, 2010 | Panasonic WORKiO DP-C262 Printer
Workio 4510
open up the front door/left upper door/pull green tab on left remove jam. if you did that and it happens again check if the fingers from the upper roller are in position
Jan 04, 2009 | Panasonic Workio DP-4520H Copier
My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
Dec 01, 2008 | Panasonic WORKiO DP-2330 Copier
Panasonic DP 4530
E4- 02 Paper Jam 1. Paper Jam in Fuser Unit.
2. Paper Exit Sensor 1 or 2 is disconnected.
3. Paper Exit Sensor 1 or 2 is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
Oct 19, 2008 | Panasonic Workio DP-4530 Copier
My Panasonic DP2500 copier
remove paper jam light stuck on, but there is no paper jam
Apr 17, 2008 | Panasonic Workio DP-2500E Copier
Panasonic workio sp-190 machine says paper jam
This series of machine has frequent issues with the sensors in the paper path to detect timing and position. The sensors are actually optical but the utilize sensor"flags" to interrupt the sesnors light "beam". These sensor flags tend to pop out of position and/or break the springs. I have also seen the actual optical sensor fail.
Dec 24, 2007 | Panasonic Workio DP-2500E Copier
Panasonic fascimile paper jam
pleaz check the paper path sensor any of them is not working or small piece of paper can be there
Aug 17, 2007 | Panasonic Workio DP-4530 Copier
Panasonic Workio DP-4530 Copier Logo
181 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
