I have a Compaq Presario F700 laptop. It was telling me I have low disk space on Presario_RD (D). I have already deleted alot files and programs and I have also did a disk cleanup and ran the disk defragmenter and I am still getting the same message. What do I need to do to free more space on this drive.
  • Computers & ... Master
  • 787 Answers
"low disk space on Presario_RD (D)"
This looks like you are running low on disk space on your D: drive, not your C:. If you were deleting files and programs, I bet it was on C:
It is now very common for manufacturers to split the hard drive into 2 partitions, C: for everyday use and a smaller D: partition that hold recovery files to restore the computer to a factory install state. If your computer was set up this way, the D: is not suppose to be used but I have run into systems were backup programs are putting the backup files on D: and filling it up.
You need to find out what is writing to D: and stop it and then remove the files it placed there.
Be very careful with D:, if you remove the wrong files you may not be able to reinstall windows if you have a serious problem unless you have created recovery CDs.
Posted on Sep 27, 2008
  • 4,338 Answers
Check the properties on C: drive. See how much free space it reports. Also, Compaq usually partitions the hard drive to C: and D: . Check how much space is on D: drive. You may be able to move your pics and music to D: drive to frre up more space.
Laptop C partition low disk space
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | HP Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like
Dec 29, 2012 | ASUS K52n-a1 Notebook
Repair manual for compaq presario M2000
Free Service Manual,
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
For additional questions post in a Comment.
Oct 14, 2011 | Computers & Internet
Over a couple of months my Toshiba Satellite Pro Laptop keeps telling me I have very low disk space. Ive removed all my pics, music and alot more! it is pratically empty now! I regulary have to run Disk...
'Low Disk Space' Could be talking about your virtual memory. Sounds as if your RAM is experiencing problems and your Virtual Memory cache is not high enough.
Jun 16, 2010 | Computers & Internet
Why does my laptop show low disc space?
The low disc space message refers to the amount of free disc space on your c drive. The c drive is the drive on which your windows is installed, thus yu need to delete some games or not neccesary files to free up some space on your drive. Hope this can help you.
Kind regards
Nov 13, 2009 | Compaq Presario Notebook
I have a compaq presario CQ60 and it keeps showing low disk space on presario _RP(D:). how do i clear this ?
empty the trash bin, delete un-necessary files you don't use. games you never play off. programs that take up space. back up the files you want on an external hard drive.
Sep 30, 2009 | Compaq Presario CQ60-204NR Notebook
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
I need more disk space on presario 1200
Let me know the space of your Hard Disk? and what is the size of your Hard Disk?
Sep 22, 2008 | Compaq Presario 1200 Notebook
Disc space
your harddrive on d: is almost full
Feb 18, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
