Question about Porter Cable Cable 19.2 Volt Grip - To - Fit Cordless Drill/Driver Kit - 9984
Porter cable 884 cordless drill
Drill bits slip/spin in the keyless chuck. this problem began when the drill was about 3 years old, under light shop use. i replaced the chuck, but the problem continues. this happens with smaller diameter bits.
  • Anonymous Mar 12, 2014
    Recently recharged year old drill, unable now to restart.
    New Friend:
  • 55 Answers
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Posted on Dec 05, 2008
How do I change the bit on my porter-cable 18v drill? Where/how do I line up the black dial with the silver dial to release the bit??
I just looked at some illustrations on ebay of Porter-cable 18 volt drills and they appear to be fairly standard cordless drill/drivers fitted with fairly standard keyless chucks that you get hold of with both hands and twist in opposite directions like you are giving it a Chinese burn. The part of the chuck nearest the bit twists anti-clockwise to loosen.
If you have an SDS drill for heavier duty jobs the chuck is semi-automatic in the drill bit just needs pushing into the chuck and clicks into place but the outer part of the chuck is pulled back in order to release the bit.
May 07, 2017 | Drills
Replace Keyed Chucks with Keyless Chucks
Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
Mar 30, 2017 | Drills
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Husband is out of town so how do you change the drill bit on the porter cable keyless chuck drill?
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
Aug 21, 2011 | Porter Cable Garden
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do you remove a bit from a cordless drill?
It should have a keyless chuck, so put the drill in reverse, hold on to the plastic chuck (just behind where the bit connects to the drill) to precent it from spinning and pull the trigger until the chuck loosens. Replace the bit in the reverse order with the drill in "forward."
I hope this helps! :)
Feb 20, 2010 | Drills
How to change a keyless chuck with a drill stick in it ?
Grab the chuck with a pair of water pump pliers, and crank it in reverse. Hang on tight. Spray some wd 40 in the chuck before you get it spinning again.
Feb 13, 2010 | Porter Cable Drills
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Porter Cable Cable 19.2 Volt Grip - To - Fit Cordless Drill/Driver Kit - 9984 Logo
697 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
