Related Tags:
This problem should be removed because:
Problem with LG LFD25860TT Titanium French Door Refrigerator
fan inside fridge not blowing
ice was building up at bottom of frezer i would chip it out every few days cause i had no idea where it was comming from now the fridge nor freezer are cooling at all
Solutions (1)
Best Solution
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Testimonial: "the compressor is working the fan is blowing but its not cold at all any suggestions or boards i could change also what would your guess be on how much i can get to just sell it to someone or an appliance company as is . thanks again"
fridge does not cool
hi i have zanussi fredge and frezer problem the freidge does not cool down and the temperature alarme sound evry 04 hours not the fridge is2...
GE Fridge with ice maker. Water is slowly leaking
at bottom rear of freezer section. It freezes before leaking out of fridge. Ice builds up in bottom of freezer and I have to chip it out...
the fridge is not working and the frezer has a low
the fridge is not working and the frezer has a low temperature
Stop cooling every 5 days I defrost manual...
I been defrosting manual ice build on frezer and stop cooling, every 5 days. I replaced mother board wr55x10656, heater kit, and thermostat....
Freezer is not defrosting.
Freezer is not defrosting. it's a RF265ABPN model
Add Your Solution
hi im needing to replace water filter for my LG...
sorry its not the fridge iv got up
The panel/screen on front of ref rig LG stays on...
Also frost in the freezer
display on front is out
display on front is out will turn on when door is opened or button is pushed. stays on for about minute then goes blank...
See all LG LFD25860TT Titanium French Door Refrigerator Problems
Related Topics
- lg dryer
- ice on bottom of freezer
- leaking fridge
- evaporator fan
- water leaks into refrigerator
- lg refrigerator
- refrigerator water leak
- fridge too cold
- Water leaking from bottom
- hot compressor
- water leaking from fridge
- dryer gets hot
- ice machine
- refrigerator cooling
- water leaks out of door
- water lg
- too hot dryer
- fridge no cooling
- water in bottom of fridge
- ice build up in bottom of...
Fix-O-Meter
230
230 people viewed this problem
- 1 person found this problem to be helpful.
- 2 people are following this problem
Top LG Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
is the freezer cold again?if it's not getting cold you'll have to check if the compressor is running,if not you could have a bad overload and relay that's on the side of the compressor but it sounds like you have a blocked drain also.you might want to call someone in to take a look at it for you or get back to me if you want to do this yourself and i'll help you out
