Question about LG DLG5932W Gas Dryer
Dryer not Heating up
I have an DLG5988B Gas Dryer (LG). It does not heat up anymore (2yrs old). I have taken it apart and checked the thermostats Hi and Safety and they both are fine except that I broke the hi limit thermostat upon removal of the wires. I checked the flame sensor contacts and found continuity threw the contacts (should they be NC or NO. I also cleaned the lint from the igniter assembly and tube because it was nasty. What else could keep the dryer from heating up? I have to wait a week to get the new thermostat before I conduct a test to see if the lent was holding me out.
Thanks
  • 943 Answers
Hi thanks for the question i would also check the thermal fuse when you purchase the hi limit thermostat also purchase the fuse a lot of dirt in venting will cause the thermal fuse to fail the appliance doc
Posted on Sep 27, 2008
Gas dryer lg trom dlg5988B does not get hot.
If it has been under water you need to have it professionally serviced. The gas igniter is electronic and there are safety circuits to prevent explosions and getting gassed..
Nov 26, 2017 | LG Dryers
LG Dryer not heating at all. DLG4802W gas dryer. Already replaced two thermostats Thermostat 6931EL3003C and Thermostat Assembly 6931EL3004B and still not heating. Only 18 months old.
Check your igniter, if that does not get hot enough it will not open the gas valve. If it does not glow at all check for voltage if voltage is present 120vdc replace igniter.
Jul 31, 2013 | Dryers
I HAVE A LG DLG2532W GAS DRYER. IT WILL NOT DRY. I HAVE TAKEN IT APART AND CAN SEE THE HEATING ELAMENT HEATING UP. CAN U HELP
Safety First, Unplug Dryer. There are two thermostats in the dryer. They are on the exhaust tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button.pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port. hope this helped Tim
May 22, 2011 | LG DLG2532 Gas Dryer
LG dryer not heating, checked thermostat assembly and their fine,any other options?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 10, 2010 | LG DLG5932W Gas Dryer
My lg dryer model dlg5988b is not drying. it seems to be working properly but is not heating.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 05, 2010 | LG Dryers
I have an LG DLG0332W gas dryer and it not getting hot. Read that the thermostat my need to be reset. have the dryer torn apart and I am having trouble locating the thermostat reset button. Where is it?
heatman101
Aug 30, 2010 | Dryers
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | LG DLE2514 Electric Dryer
Lg dryer wont heat up DLEX7177RM how do I reset the thermostat
heatman101
Apr 30, 2010 | LG DLG3788W Gas Dryer
Taken to long to dry
IF ELECTRIC
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
IF GAS
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Aug 21, 2009 | LG Dryers
LG gas dryer model # DLG5988B won't heat
turn the gas on or you might have air in the line.
if that dont work check out the ignitor
Dec 09, 2008 | LG DLG5988 Stainless Steel Gas Dryer
LG DLG5932W Gas Dryer Logo
301 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
