I bake alot so having problems with the wall oven.It turn's off and starts beeping and F3 code appears. If it's simple, I would like to try to repair myself. Thanks a million!!!
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Sorry, it looks like your baking (in this oven, anyway) is over for tonight.
For Whirlpool ovens, F3 means that the main control circuit board is reading a temperature that is too high. The E2 code indicates that the temperature sensor has probably failed and needs to be replaced. It's a fairly easy fix for a service person, but you are probably not going to get the parts and/or technician before tomorrow.
Wish I had better news for you. Hopefully, it's under warranty!
F3 error code is telling you the oven temperature sensor has failed on the oven. You can access the oven sensor from inside the oven. The sensor is a stainless steel probe about 1/4 inch in diameter and several inches long. Disconnect the power to the oven and remove the screws that secure the probe to the rear oven wall and you can usually pull it into the oven.
F3 is a bad temperature sensor. Look in the top left or right of the oven for a short thin round metal piece sticking out of the back of the oven. Turn off the power to the range. Remove the screws,carefully pull the wires out through the front. Replace it with a new temp sensor and bake away.
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
These are the F2/F3 error codes for a Tappan oven
F2
Oven
too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven
temperature sensor open
Check
oven temperature sensor, should
be ~1100 ohms at room temperature. If too high or low, replace
oven temperature sensor please take the time to give this solution a fix ya rating.
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
