Phillips 51HX40B Shuts down after a few seconds.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
This will happen if the fan filter is blocked, Remove this and see if it needs cleaning , also in the menue , check to see the remaining lamp life? ,
Posted on Sep 27, 2008
Phillips/Magnavox tv shuts off after a few seconds led stays lit model # 32PS55S321
SDA [Serial Data] line should be checked. It is a skilled job. Best is to contact any expereinced service technician.
Sep 04, 2013 | Televison & Video
Panasonic PT-51hx40b projection TV powers off when I try to turn it on
Not sure if the transformer is bad or something on secondary side is pulling the voltage down--if replacing it cured the issue you did good.
If not try to disconnect at source on secondary side to see if with no load the voltage comes up.
Looking for either the xfmr to be bad or something shorted pulling the voltage it creates down.
May 14, 2012 | Panasonic Televison & Video
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
I have the Phillips/Magnavox 3 CD Rotary Changer System and when I try to power down, it shuts off for a few seconds and then goes into Demo mode. How do I power off completely?
without the model number i cant be exact, but if memory serves me you either hold down the demo or display switch for about 5 or 6 seconds
Sep 07, 2010 | Audio Players & Recorders
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Wont stay on turns on for a second then i hear a
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Apr 17, 2009 | Philips Televison & Video
hi there, check your power supply on cpu if theres a tripping off , so if theres then replace power supply. then switch it on again. then let me know what happen nexr..
reagards rated me... thanks
Mar 31, 2009 | Acer AL1715 17" LCD Monitor
Laptop doesn't work on battery after charging
If you are planning to open the notebook make sure the cpu cooler is mounted flush and has the most possible amount of contact with the cpu for heat transfer. I don't know about yours but normally in bios you can set a fatal temperature shutdown. Try to look up what cpu you have (when you open the case) and see if maybe the temperature is set too low. Then you would be able to reset the temperature to something higher if possible and this would solve the overheating shutdown problem.
Jan 02, 2009 | Computers & Internet
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
