Question about Motorola T5000 Two Pack 2-Way Radios with 5 Mile Range
When i transmit to one of my Motorola T5000 2-way radios, it makes a crackily sound through its speaker. When the problem one makes its own sounds (beeps and calls) it is okay though. There is only a problem when it recieves a transmit from another 2-way radio.
  • Motorola Master
  • 1,654 Answers
Generally a crackling sound coming through a speaker indicated the speaker is damaged (or blown). This can happen due to phyical damage such as dropping; old age' or running the device at full volume most of the time. The T5000 is a non-repairable radio. If less than one year old you may be able to get it replaced under warrranty. If more than one year old, you will need to replace the unit.
Posted on Oct 01, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 71 Answers
Could be due to air blowing the mic or something but please remember that usually transmissions are fuzzy,
Posted on Sep 30, 2008
How do I get the Motorola T5000 and Boafeng UV-8D radios to communicate with each other?
check you settings in the radio,follow your instruction manual for the radio
Jun 11, 2015 | Motorola TalkAbout T5000 2-Way Radio
I can transmit to one talkabout but the other person can't transmit to me
Check your programming, it sounds like your Code is not set the same between the two radios. Here is a link to the user guide http://shop.giantintl.com/Manuals.asp Choose your model from the page or the pulldown.
Feb 01, 2014 | Motorola TalkAbout T5000 2-Way Radio
K7gmrcej motorola radio
Parts are not available for this model radio. Speakers generally are damaged from debris or moisture getting into the speaker. They are especially susceptible to small metal fragments due to the magnetic properties of the speaker.
Oct 09, 2013 | Motorola TalkAbout T5000 2-Way Radio
Frequency range motorola t5000
http://shop.giantintl.com/Manuals.asp?offset=30
Sep 28, 2013 | Motorola TalkAbout T5000 2-Way Radio
Cannot receive or transmit
A few items to check:
Be certain both radios are set to the same:
Frequency
Interference Eliminator Code
Qt filter
For a simple test set the Code, Qt filter, and any other special features to off or zero. This will allow you to find out if the radios will work simply on their frequency. Once you establish this, you can add in the features as you need them.
Here is a link to the T4900 & T5100 user guides (couldn't find T5000 alone.):
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4800_UserGuide.pdf
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXx_User_Manual_E.pdf
Best regards.
Jun 26, 2012 | Motorola TalkAbout T5000 2-Way Radio
I hunt in a remote area. Will the t5000
If your farm radios are FM UHF radios, it is possible they could communicate if programmed to match one another. You would need to limit your wattage on the farm radios to 1/2 watt on the FRS (family radio service) channels, which are in the T5000.
Your T5000 will NOT match CB (citizen band radios).
Best regards.
Feb 28, 2010 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola T5000 Rx problem
Hi SirDrag,
Your concern could be the internal speaker of the T5000. This could be verified by attaching an external speaker or a headset compatible with the unit through its accessory jack. Should this be the case, it of course would require replacement. Though Motorola speaker for this model is proprietary in design, those made for Alinco, Icom, Kenwood and/or Yaesu should also work. The only concern would be getting one that will fit the physical mounting limitations of the front cover.
In some instances, it could be the volume control developing blind spots along its carbon pad. A spray from an electronic contact cleaner should do the job (albeit temporary).
It is also possible that the Interference Eliminator Code setting is different with that of the TX radio.
Worst case possibility is a defective electronic component (such as the op amp) which would then require the professional services of a qualified communications technician.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
2-WAY RADIO TROUBLESHOOTING
In a Motorola T500, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Nov 03, 2007 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola t5000
If you have already checked both radios have the same code and channel both radios must reicive and transmit between each other check if you have any QT in any display this is a third condition to reicive.
Jun 06, 2007 | Motorola TalkAbout T5000 2-Way Radio
Motorola T5000 Two Pack 2-Way Radios with 5 Mile Range Logo
169 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
