Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Pump leakage ge spacemaker washer pump cleanout leak (rear lower right access port) I think I need a new seal. Is this possible?
  • 725 Answers
Yes but the coin trap just may be misaligned try to open it and lock it back in place...let me know
Posted on Dec 25, 2008
My washer is leaking and won't agitate properly.
I had a similar problem with my GE Washer that leaked, and still won't spin. I fixed the leak though. It was from the pump, which is in the bottom front, and somewhat easy to get to. I just removed the front cover, and the pump is on the right side. The pump itself was not broken but one of the screws was corroded with rust, so water leaked from that area. I just had to take it apart, put in a new screw to get a tight seal, and no more leak.
Mar 11, 2015 | GE Spacemaker Washer and Dryer Electric...
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
"GE Quality Product Spacemaker Laundry"
you could have a broken belt or a frozen pump pulley. the leak has to be addressed to see where it's coming from. it could be from the pump hoses/connections. it could be the main tub seal that's leaking. if you're not handy with tools and test equipment, i suggest you call someone to have a look at it. these are problems that wont be resolved by pushing a button.
and thankyou for using this site. i hope you will continue to use this site.
if you have any further quesions or need further advice, repost another question. be sure to include the model number as well. you gave a good explanation, and that helps. anything you can think of can be of assistance
thanks,
mike
Jul 07, 2011 | GE Spacemaker Washer and Dryer Electric...
Water leakage
its possible when you are doing a big load it demand more water so the water goes true the agitater seal which is located under that white agitater the seal is between the two shaft thanks from gilles
Mar 14, 2009 | Washing Machines
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
201 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
