Samsung hcm4216w hi here is the problem the tv green is very fuzzy...and having problems with the blue .... when i do convergence there is no blue crosshair.........red is fine......green is fuzzy....but there is no blue in convergence...the blue tube is on i can see it light up but there is no blue in the video .....all you can see is like a blue distorted blob in the center of the tv when watching a show ..... can you help me?
  • 8,617 Answers
Can you look into the blue lens when the set is playing using a hand held mirror and see if there is a picture in the blue CRT. If not you will need a new tube for the blue. If you do need a tube let me know as I have a source for good used tubes that are very reasonably priced.
Posted on Sep 27, 2008
My samsung HCM4216W TV has 3-D effect i was told it is a conversion module for the bulbs is this right
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2011 | Samsung HCM4216W 42" Rear Projection...
The green and magenta convergence on my tv is off. The picture is also...concave(?) I've tried unplugging the tv for 10 minutes and the solved nothing. What else can I do?
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 08, 2009 | Samsung HCM4216W 42" Rear Projection...
Red and Blue convergence issues cause triple-image
This sounds like your convergence chip is bad. If you are good at soldering you can order the replacement kit from www.tvrepairkits.com and do it yourself.
Apr 17, 2009 | Samsung HCM4216W 42" Rear Projection...
The colors primary red,green and blue malfunction
the convergence ICs are most likely the cause of your problem. You can get replacement ICs at the following link with free instructions.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung hcm4216 projection tv blue color problem
first of all in setup mode(where convergence is)select blue screen off.then go to picture mode and either select a set mode,or enter user and manually set contrast,brightness,colour,sharpness and tint.you can acheive near hd quality this way on non hd projtv
Feb 24, 2008 | Samsung HCM4216W 42" Rear Projection...
HCM4216W
most convergence problems if they can't be adjusted come from chips called stks.. if they go out they have to be replaced. DId you get any result.s does the colors adjust at all?
Dec 06, 2007 | Samsung HCM4216W 42" Rear Projection...
HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Sep 25, 2007 | Samsung HCM4216W 42" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Replaced bulb and converge problems
After replacing a Picture tube convergence/geometry allignments can be quite extensive and if they're not fairly precise the sensors for the auto conv. can not be calibrated therefore your auto conv. not working as you described. The key is usually the geometry start with the green lines and get them as square as you can then align the red/blue. Since the auto is not going to blue that often means the blue is to far out and the sensors are not picking it up.
Apr 21, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
