Question about HP DeskJet 9800 InkJet Printer
Cartridge stalled after replacing cartridge. Resume and Power lights blinking together. I
The cartridge is stalled at the right side. There is no paper jam. There are no print jobs in the que. I have unplugged and turned back on (more than once.) Also, I noticed somewhat of a mess at the cartrigde "station" on the right side. (I assume cleaning station.) I thought I removed the plastic covering, if I didn't what is solution?
  • 5 more comments
  • jt83 Sep 27, 2008
    So what do I do now? Take the printer apart???
  • jt83 Sep 27, 2008
    Before I embark on what (for me) will be major undertaking, are you certain there is not a way to get the cartridge to return to the left side so I can remove the cartridge?
  • jt83 Sep 27, 2008
    Again, the cartridge is STUCK over on the left side. I cannot get to the cartridge (without, I assume taking something apart).
  • jt83 Sep 27, 2008
    Sorry, my the CARRIAGE is stalled at LEFT SIDE, not the right side.
  • jt83 Sep 27, 2008
    The carriage stalled at the LEFT side after I replaced the color cartridge. Apparently, but not absolute certain, I may have left the plastic cover on the cartridge. I cannot get to the ink cartridge to remove it. I noticed there is moisture at the right side where the cartrdiges set when you replace them. Both the Resume and Power buttons are blinking. How do I get the carriage to return to the right side? There is no paper jam.
  • jt83 Sep 27, 2008
    I will try taking it apart.
  • jt83 Sep 28, 2008
    Sorry, but I give up. I cannot see even how to remove the top. I am going to search the internet to see if I can find detailed instructions on how to take the printer apart. I DO NOT ACCEPT ANY OFFERED SOLUTIONS AT THIS TIME.
  • 2,071 Answers
The carriage remain stuck on the lift side,probably cause by gear misalignment .Open the cover try to tapped the carriege or try to look cause the stuck up.Are you using compatible cartridges? If so have you removed any tape that covers the vent hole if required. Many compatibles need to have a piece of tape removed. If you forget the ink cant get out as the air can't get in.
If it not a piece of tape and there are no flashing lights it could be that the nozzles are blocked or the wick has dried out.
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR ink jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor.
There is another possibilty after this which relates to a hardware problem but this generaly causes a loss of all ink.
Hope this may help;
Regards,
VOTIT
Posted on Sep 27, 2008
    New Friend:
  • 41 Answers
Dear Sir/Madam,
Open the top cover and unplug the power cord. Wait for the
Resume and Power lights to go off. Close the top cover and
plug in the power cord. Wait for the printer to reinitialize and
resend the print job.
Or remove the ink cartridge first, unplugged the power cord of the printer then try cleaning the waste drainer of the printer.
if the ink absorber is too full.. try change it with a cotton like material or use something like the original..
  • Rommel Aberca
    Rommel Aberca Sep 27, 2008
    Dear Sir/Madam,
    or try this one.. turn off the printer, turn it back on, and then try to print again. If
    the problem persists, turn off the printer and disconnect the
    cable from the printer. Reconnect the cable, turn on the
    printer, and then try to print again.
    Master:
  • 479 Answers
Its the problem of gears in your printer as they are not able to move frequently and so not able to bring the printer in proper position as it should be.it could be because of three reasons.
1)due to some kind of blockage or dust in them. so just open the printer and clean them.
2)due to some kind of misallignment they have lost there there position so open the printer and adjust them properly apply some greece material between the gears.please take care the greece material should not be applied any where else the gears .
3)due to the gears are broken or worn out so you have to replace the gear assembly.thats quiet difficult but the assembly is not very cheap not more then 10$.
opening the printer is not very difficult as there there r four screws two in the front and two in the back just remove them and lift the upper cover slowly.and then have a look in the printer and check if any thing is broken or any piece of paper or any other object is blocking the gears.they r present on both right and left sides so check both sides. do everything slowly and carefully.
  • tech gurus Sep 27, 2008
    just OFF the printer and remove the power adpator wire from the back of the printer and just lift the cover of the printer and you can see the black colour rubber belt in the printer the carriage of the cartridges moves on that belt slowly with the help of the hands pull the belt towards right side .do not pull the belt towards you just try to pull it towards the right side .slowly----slowly bring the cartridges to the center by pulling the belt.and remove both the cartridges.then just connect the wire of the printer and ON the printer and then install the cartridges as per the procedure as u regularly do when you install.and then it will work.if the power light/resume is blinking continusly then either the cartridge is not fitted properly or any of the two cartridges must be faulty.try replacing them 1 by 1.it will work.
  • 65 Answers
Remove the cartridge first... try to plug it again carefully by following the instructions given on the manual of your printer... everything will be fine..
  • HP Master
  • 6,487 Answers
Yes, you may need to take the printer apart to clean everything and also to make sure all part are still fine...
  • 1 more comment
  • Mark Gil
    Mark Gil Sep 27, 2008
    You really need to take the printer apart so you can check also all parts of it and also to check if there's any foreign obejct inside it that is causing this problem...
  • Mark Gil
    OK no problem just inform us for any update on what happen if the problem was resolve or not, good luck...
  • Mark Gil
    Mark Gil Sep 28, 2008
    This user manual will be helpful to you in taking the printer apart http://eit.tamu.edu/CostShareArchive/fal...
    Hope that helps...........
    Scholar:
  • 148 Answers
YOU DID NOT REMOVED THE STICKER ON THE CARTRIDGE, AND THE PRINTER WONT PRINT, OR THE PRINTER WONT FEED A PAPER..
KEEP ME UPDATED
I have an HP Deskjet 6980. After changing the black ink cartridge i tried to print. The printer takes the paper but doesnt print, just the Power and the resume lights are blinking. If I press the resume...
The printer might be working but the cartridge is not connected properly. Just open your printer, remove the cartridge and replace it back in its right position.
Mar 25, 2011 | HP Deskjet 6980 InkJet Printer
Inserted new printer cartridges but printer still says"remove and check cartridges" help!!
after any maintenance the printer need to be told that the cartridge has been filled in order to do this you need to reset the error count messages
push power button & resume button together then push the resume twice before i release them together..the result is the blink light stop
hope this helps
Robb
Apr 26, 2010 | HP PSC 2175 All-In-One InkJet Printer
Deskjet 895Cx1 Green and Ornage lights flashing together Problem & solution, please
Please find below the section in the user manual for the printer that tells you what the lights mean. Hope this helps.
Sometimes the lights on the printer signal a problem:
Both lights are off
• The printer is turned off. Press the power button. If you still don’t see the glowing green light, make sure the printer is plugged into a power outlet and that the outlet has power.
Both lights blink
• Paper may be jammed in the printer. Open the front cover and remove any jammed paper. Close the front cover and turn the printer off, then on again. Go to “Clearing a Paper Jam” on page 67.
• The cartridge cradle may be jammed.
Close the front cover, turn the printer off, then on again.
The power light blinks, and the resume light is off
• This is normal behavior when the printer is receiving data, printing, or waiting for ink to dry.
The power light glows steadily, and the resume light blinks
One or both of the inkjet printer cartridges may not be seated properly, or you may have forgotten to remove
the tape from a new inkjet printer cartridge. Open the front cover. Remove both inkjet printer cartridges. Holding the black plastic sides of the inkjet printer cartridge, check to be sure the tape has been removed from the print head. Then replace the inkjet printer
cartridges in the cartridge cradle. Make sure each inkjet printer cartridge is pressed all the way into the cartridge
cradle. If an inkjet printer cartridge feels at all loose, it is not properly seated. For instructions, go to “Insert Print Cartridges” on page 5.
• The front cover may be open. Make sure it is closed.
• There may be no paper in the lower paper tray. Load paper.
• The printer may need to reset. Press and release the Resume button.
• Your computer may be low on memory. Try restarting it.
• Turn the printer off, then on again. (This resets the printer.)
• Repeat the printing process.
Sometimes problems disappear when you try to print your document again.
• Printing problems can often be caused by errors in your applications.
If you can print from the SimpleText or TeachText application but not from another application, it’s probably a problem with that application. Contact the publisher of that application for help.
• Restart your computer.
Nov 22, 2009 | Apple HP DeskJet 895cxi InkJet Printer
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Power button is blinking and Carriage is stalled
    there are two cartridge one is the ink cartridge which can be found on the left side of the printer (in front)and the other one is the head cartridge that can be found on the right side if you will open the printer cover that is the carriage check it if the flip cover is lock properly then try to reinsert the head cartridge..
    Sep 10, 2009 | HP OfficeJet Pro K5400dn OfficeJet Pro...
    Error caused by paper jam - but there's no paper jam
    the carriage (carriage stalled) in jammed in the right side of the all in one, try slowly free it, also check cartridge status.
    (carriage stalled in process of cartridge cleaning)
    May 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    Cartridge seems to move smoothly. Just get the
    There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
    STEP 1: Clean the printer from inside
    1. Opened the cover and checked the front right of the printer near the waste ink pads
    2. Carefully turn the cogs to move the ink cleaning mechanism
    3. There might be a load of paper jam debris blocking the mechanism from reaching its port
    4. Carefully cleaning this out and putting the printer back together
    STEP 2: Reset the error
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    6) Power off then back on and test.
    Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
    The printer apear to be dead!
    Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
    • The lights tell when the printer is working or when it needs attention.
    • The buttons help control the printer.
    Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
    All lights are off. The printer is off (asleep).
    Press the POWER buttonc00123886.jpg to turn the printer on.
    The printer should turn on automatically when a print job is sent to it. c00123898.jpg
    The POWER (top) light is on. The printer is idle.
    The POWER (top) light is blinking. The printer is busy printing.
    Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
    The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
    • The front cover is open. Make sure the front cover is completely closed.
    • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
    • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
    Black: 51645A
    Color: C1823D,
    If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
    If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
    Jan 20, 2008 | HP DeskJet 710c InkJet Printer
    Cannon BJC 80
    5 times try this:
    1: Unplug Power Cord
    2: Hold POWER and RESUME buttons
    3: Plug in Power Cord
    4: Release buttons after the printers starts up
    5: Hold CARTRIDGE and RESUME
    6: Press POWER
    7: Release all buttons after the beeps
    8: Press CARTRIDGE 16 times
    9: Press RESUME
    10: Unplug the Power cord
    3 times, probably something wrong with the cartridge.
    Nov 21, 2007 | Canon BJC 80 InkJet Printer
    HP DeskJet 9800 InkJet Printer Logo
    206 people viewed this question
    Seeker5211
    Seeker5211
