Question about Samsung LN46A550 LCD TV
Puprlish bright whites
All bright whites come through looking lavender with a 'halo' around them.
this just started happening - no change to setup
    Master:
  • 479 Answers
Check out on the main board it could happen due to moisture on the board.
or keep the unit ON for some extra time it may start working properly as the board gets heated and the moisture may start disappearing.
Posted on Sep 27, 2008
    Scholar:
  • 148 Answers
Try to reset the color orientation of the tv.. and also i want to know if theres any near magnetic object on the tv.
keep me updated
Double images and bright pink and green colors
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 21, 2010 | Hitachi 43F300 43" Rear Projection...
Colour fading bright halo type around white
Dec 20, 2010 | Philips 60PP9202 60" Rear Projection...
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
I cannot set ip the convergence in the setup menu, 2 years ago a similar thing happened and the repair man said it was the convergence chip and a fuse. does this sound like the same problem? mikw
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My tv ,whites glow way too bright,dark colors way to dark,what is wrong
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Feb 08, 2010 | Philips 60P8342 60" Rear Projection...
White halos and foggy screen.White is very bright
This is a very common problem with Projection sets. The CRT fluid has clouded over. Typical symptoms are...
  • Dull looking video
  • White looking video
  • Red/Orange looking video
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
Excessively bright whites...has a haze around any white items. all other colors are fine.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
May 12, 2009 | Televison & Video
Convergence toshiba 50a62
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
Warped picture Toshiba 65HDX82
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Nov 14, 2007 | Mitsubishi VS-50703 50" Rear Projection...
Samsung LN46A550 LCD TV Logo
108 people viewed this question
Henry  Thomas
Henry Thomas
