Question about Acer TravelMate 2300 Notebook
Acer 292 dry rot ,,need to open laptop
  •  Andrew Smith
    Andrew Smith May 11, 2010
    Be specific please! I need to know the problem!
    Is it:
    Hardware Broken?
    Cant load?
    Give me more information! So I can try to help you!
  • 78 Answers
You can have a look here. I did it.check this link.
Posted on Feb 28, 2009
CB250 is backfiring
Backfire when throttle down can be;
1. dirty carbs that are running lean and need cleaning. Also the rubber grommets that hold the carbs can be leaking at the backside or even dry rotted.
2. no air filter
3. broken or open vacuum lines
4. an aftermarket exhaust that needs rejetting or an open exhaust system
Dec 15, 2012 | Honda CB 250 Nighthawk Motorcycles
May i upgrade my notebook
1) Intel T7700 [ 2.4GHz, and 800MHz FSB ]
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Merom.22.2C_.22Merom-2M.22_.28standard-voltage.2C_65_nm.29
2) 4GB of DDR2 Sdram (SO-DIMM) that is 667MegaHertz.
(PC2-5300)
3) Seagate Momentus XT 500GB harddrive
Graphics upgrade? No.
Regards,
joecoolvette
Sep 17, 2012 | Acer Extensa 5620-4020 Notebook
What is the P0440 trouble code on a 97 850 volvo non turbo
Code is for the evap system which vents gas fumes from the tank.
Could be anything from a bad gas cap to a leak in the vent system.
Jun 27, 2012 | Volvo 850 Cars & Trucks
How do i switch wifi on on acer 5750 z laptop
Try going to: start>control panel>network and internet>network sharing center. In the left pane click; change adapter settings. You should see your wireless adapter here. Right click and click enable.
Mar 20, 2012 | Acer Computers & Internet
I have acer aspire i3 laptop, accidentally a glass of water hit and went to my laptop. after that i cannot open my my laptop anymore, want to know what happen and what is the best solution. tnx
pull out the battery as soon as possible. and try to dry it first with the electric fan, or any device can make it dry. avoid heater, do not try to disassemble the device. dry it first.... with in 5hrs...
Jun 10, 2011 | Computers & Internet
Key function for letter inye
keyboard error maybe cussed by :
1. the data cable was loose --> open the keyboard from the laptop and the data cable from the laptop than clean the data cable wait until dry and plug in again use the duck tape to strengthen the cable data connection in the main board.
2. dirty --> open the keyboard from the laptop open all the key (carefully) than use vacuum cleaner to clean all of the dirt or use blow it with air compressor
3. moist --> open the keyboard from the laptop than dry it on the sun or yo can use hair dryer
May 13, 2011 | Acer Aspire One PC Notebook
Changed pads and rotors on the front end, and now the pedal basically goes to the floor. It's a 2007 Dodge Caravan SE, and the rotors, calipers, piston covers, bracket, and the pads are all dry rotted,...
try holding the brake pedal down overnight with a broom jammed into the seat ?? if that doiesnt work then bleed the brakes and if still no joy then ask a local mechanic to diagnose for you before you spend a fortune on unecessary parts
Aug 29, 2010 | 2006 Dodge Grand Caravan
96 Suzuki Sidekick JX (86K mi.) has 5 yr old
Another problem. Cupping would be from alignment. Dry rot is dry rot. All tires will do it.
Mar 15, 2010 | Suzuki Sidekick Cars & Trucks
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
