Enter your VCR model number in the box. Click CONTINUE. The next page has the link to download user guide in PDF format. Click on the link Operating Instructions to download manual.
Check video input setting to DVD recorder...should be set to "External" or "Line". This should activate the video input jacks on the rear of the RDR-VX530 and allow it to "see" your Sony handycam.
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
display panel on sony video cassette recorder has failed
