Question about Miele Dryers
Have a miele t9800 dryer with broken belt. Where do I find and how to I replace
4 Suggested Answers
paulc118
  • 15 Answers
SOURCE: Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: Dryer Miele T9800- 3 years old Lately the air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 14, 2010
heatman101
  • 43501 Answers
SOURCE: Miele T9800 dryer starts then stops and goes dead.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 19, 2010
Why the slow blow fuse in miele t9800 lt is burnin ?
because your vent is probably clogged up
Feb 01, 2015 | Miele Dryers
How do i replace dryer belt
You have to disassemble your Miele dryer to get access to the drum and the belt for replacement.
Jan 14, 2015 | Miele Dryers
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
Will this be expensive to fix or could i t be relatively cheap? Drum wont turn, even by hand. Opened up found broken belt.
you need to strip the dryer to bits and remove the drum
sounds like you need a new bearing and it needs a dam good clean inside some oil etc
the belt has broken because its stuck on one place on the motor
check out the bearings and dust etc
sometimes the bearing has just dried up and can be soaked in petrol or etc then oild for a day
so .. cost = 0 other than a new belt
if you feel you can take it too bits and clean it all then its cheep
A loud clunking noise - the vent/filter check light came on plastic broken parts which looks like a fan or something.
Hi
Yes, your right, it is the blower fan for the dryer, something may have gotten down the filter element housing and broke it, or just from heat and time.
Yes, you can fix it if your somewhat mechanically inclined.
It is not a hard job, but must be done correctly.
I will send you a webpage with some parts choices.
I do not know where you location is so I cannot send you to the direct webpage.
Please rate me
Bud
parts webpage: http://www.ask.com/web?q=Miele+T9800++parts&qsrc=6&o=11145&l=dir
Youtube video on Miele dryer repair, not your model but will probably dissassemble the same way.
http://www.youtube.com/watch?v=Kl7jTH2d58A
Oct 26, 2012 | Miele T9800 Electric Dryer
Dryer belt t9800 keeps breaking
worn felt seal on the front of the drum. felt has worn away exposing the rubber, when the dryer gets warm the rubber gets sticky. this causes loud vibrations and friction. the drum wont turn so the belt breaks. i would not trust this job to any one but a miele tech, as it is very complicated and someone that does not know how to work on this dryer can cause more harm than good.
Jun 17, 2012 | Miele Dryers
Miele T9800 stopped, made a humming noise and now it makes a horrible noise
felt seal on the front of the drum is bad. call miele for service. this is not a repair that a normal company can perform. you have to get the part from miele, and it is very complicated to repair.
May 21, 2012 | Miele T9800 Electric Dryer
Where can i get a blower fan for a Miele T9800
only from miele. 800 843 7231. press 0. ask for parts.
Apr 13, 2012 | Miele T9800 Electric Dryer
Drum is not turning
Replace your broken drive belt ...
Jul 06, 2010 | Miele T9800 Electric Dryer
Feb 18, 2010 | Miele T9800 Electric Dryer
Dryers Logo
44 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
