Question about McCulloch MC1275 Steam Vacuum
Chain saw starts runs, bur saw won't start next time it is needed, craftsman chain saw
Saw wil start, runs, and cuts a limb, shut unit off and try starting again and it won't fire. model 353660, s/n 205 12284.
  • 39 Answers
Steam vacuum? no clue but on your chain saw make sure you check the choke. it would explain why it wouldn't start again.
Posted on Jan 16, 2009
Delta 36-600 table saw new belt run's and sounds great, BUT wont cut butter?? Any help would be great thanks. Oh could it be brushes?? Cheers Matt Blade is in the right way,Delta 36600 have brushes.
Not to insult your intelligence, check the blade direction. Looking at the tablesaw from the left side, the blade should be turning clockwise and the teeth cutting downward. Also the teeth should be very sharp. Typically a belt run tablesaw doesn't use brushes but a capacitor to start rotation. You didn't mention if the blade turns when started. Since you mentioned it sounds good when started I'd rule out the motor. Some saw blades have an arrow to indicate direction. Hope this helps. Good luck.
Oct 28, 2017 | Vacuums
If my Oreck Magnesium upright needs a new sensor, what might it cost to repair?
Try pressing and holding the start button for about 15 seconds and see if the vacuum re-starts. The power board would probably run you somewhere between 3$35-$50 plus labor if your machine is not still under warranty. If it is still under warranty, it should cost you nothing.
Sep 10, 2015 | Oreck Vacuums
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
Can you put an 18 in. bar and chain on a poulan 2055 14 in ?
Have you considered a rental? Home Depot rents Makitas (Dolmar) with a 20" bar reasonably. Be warned running a Dolmar/Makita will make you question the value of your Poulan LOL. HTH
Lou
Dec 07, 2009 | Vacuums
Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
May 09, 2009 | Shop Vac Vacuums
Table saw not turning on
yes that is a thermal fuse. wait a couple of minutes and reset it. If the blade is dull, replace it.
May 02, 2009 | Vacuums
Mc Culloch chain saw
You will need a parts breakdown and exploded views to start with as well as a manual , All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
After that is done then you can see the fuel filter and line inside the tank you will need to replace, take your printed views and manual to the nearby lawn mower shop and they will help you get the parts you need even if the original ones are not available. blow out the carb with chemtool and install the parts, use NEW GAS, NEW OIL and from that day forward never leave fuel in a unit for more than 3 months. Good Luck...
Aug 18, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
McCulloch MC1275 Steam Vacuum Logo
134 people viewed this question
Top McCulloch Vacuums Experts
JoeVacs
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
